Main > Project Announcements
Crackington Cocktail Cabinet (Made in Cornwall, UK)
rchadd:
you can sort of get the idea from this photo through the tinted glass
Grasshopper:
--- Quote from: rchadd on October 16, 2004, 08:18:59 pm ---i am wondering if it is possible to modify the standard white Happ P1 and P2 buttons to be lit by LED (i got some spare). any ideas?
http://www.arcadeparadise.org/arcade/ap3/lighting.html
Gillisdc:
Can i ask you how did you do the wiring if they are hotswapable ?
(they = Control panel)
I liked the idea so please tell me :)
Thx
G.
BobA:
From the interior view it looks like he has wires to the CP area that are fixed so he probably uses a connector to swap to different control panels. Maybe a male and female DB 25. The encoder will not know if the cp is swapped out so hat swapping is easy as long as nothing is shorted when connectors are exchanged.
Just my best guess
jimmy2x2x:
Great looking cocktail, well done!
To change the control panels, you remove the glass top and uncouple the db25 then replace?
Also are those metal hooks from the control panels the only things holding them in place, how solid are the panels when in use - is there any movement?
