Main > Main Forum
--- BYOAC CHAT ROOM ---
missioncontrol:
--- Quote from: sirwoogie on December 29, 2004, 01:34:05 pm ---mc,
That is the correct URL, and is working properly in my reference browsers. I tested the functionality with Mozilla 1.6, Firefox 1.0, IE 6.0, IE 5.5, and Opera 7 + Java. Are you you have a properly installed JRE for your machine? What is your client spec with regard to the following:
* OS/Platform
* Java Version
* Browser
OS---windows 2000
Java Version---(I don't know how to check)
Browser---IE 6.0
saint:
Did you clear your cache?
ChadTower:
Won't work for me either, W2k using IE6.
class EIRC not found
sirwoogie:
Hrm... both 2k under IE 6.0. I have 6.0 under XP and experience no problems. The HTML syntax appears correct to me, but the symptom says otherwise. I'll have to do some further investigation.
edit: There appears to be some discussion on this combination in a Google search. No solutions yet.
edit2: It appears there is no concensus on how to fix this problem. The only think I can suggest is to upgrade the JavaVM to the latest from Sun and see if that eliminates the problem: http://jdl.sun.com/webapps/download/AutoDL?BundleId=9812
missioncontrol:
--- Quote from: sirwoogie on December 29, 2004, 03:53:10 pm ---
that appears to eliminte the problem for me......
