Author Topic: P360 issue or PSX Hack issue?  (Read 769 times)
mcdo15
  • Last login:February 16, 2008, 01:49:17 pm
  • why can't i make up my mind
« on: September 25, 2004, 09:48:08 am »
hello.. i have some ps2 hacks with a +5 connection for p360
i wire it up and on game controller properties on ps2 to usb converter... the controller is moving it self and all buttons light up like it's xmas time.  Buttons that don't even have a connection are lighting up also
then...i take that same controller, put it to a compititon stick, it works fine ( i just don't hook up +5 to anything)
where would my problem be?  i ordered p360 (2x) a few month back and havn't used it since.  since it's opitical, does it get dirty?
 thanks for your help
Bgnome
  • Last login:January 10, 2005, 04:05:16 pm
  • Who's da gnome?
Re:P360 issue or PSX Hack issue?
« Reply #1 on: September 25, 2004, 11:16:22 am »
if you are trying to get the 5v off the controller, that most likely is your problem.  if you are using an alternate source for the 5v, try using an alternate ground as well.
TalkingOctopus
  • Last login:September 06, 2023, 03:39:02 am
    • My Arcade
« Reply #2 on: September 25, 2004, 12:06:05 pm »
It is a hack issue.  Do you know what controllers are you using?  The standard PS2 dualshock controllers cannot be used with P360s because they are fully analog.
mcdo15
« Reply #3 on: September 25, 2004, 12:54:41 pm »
i don't know which pad it is...
it came from a  member of this fourm that does stuff like this.
it came tested to me successfully.
what should i try next?
where else can i get a +5 connection from?  IPAC doesn't have thing on it right?
Gunstar Hero
  • Last login:September 28, 2014, 01:51:17 am
  • Back in action!
« Reply #4 on: September 25, 2004, 12:59:18 pm »
The IPAC does have a +5v connection. Check out the diagrams at Ultimarc for your model to find out where.
mcdo15
« Reply #5 on: September 25, 2004, 04:28:39 pm »
so i test it with the ipac and it works....
thank you all
New question?
i have 2 p360, can i wire them both to the same +5 connection i should i seperate it?
« Last Edit: September 25, 2004, 05:05:28 pm by mcdo15 »
Gunstar Hero
  • Back in action!
« Reply #6 on: September 26, 2004, 04:27:13 am »
I did.
It's been working fine for over a month now.
Course, you may wanna wait for a second opinion!
