Main > Software Forum
Can't use trackball in Marble Madness????
SirPoonga:
what version of mame are you using? commandline mame or mame32.
If commandline mame look in the mame.ini file in your mame folder.
If in mame32, goto Options/Default options...
Click on the Controllers tab and enable mouse input.
Brax:
I'm using both mame 36 for dos and mame 60 for dos. Neither have a mame.ini file. There is a mame.cfg file in mame 36 and it has mouse=yes.
I can't believe its so hard to enable the mouse for a game that is SUPPOSED to use a trackball! Wierd.
SirPoonga:
did you ever do a mame -cc with version 60?
Brax:
ahhhhh
its -createconfig btw.
it works now. Like i've said before I haven't messed around much with the software settings. I'm more of a hardware guy. I don't have a dedicated computer yet either so its not in its final setup yet either.
After i did the createconfig I got my ini file and i set it to mouse=1. it works now.
SirPoonga:
-cc is short for -createconfig, both should work.
