Author Topic: I-PAC and Happs Trackball interface  (Read 2528 times)
TRIBOY
  • Last login:March 03, 2005, 05:13:05 pm
« on: September 23, 2004, 12:16:42 pm »
I am a newbie and have read Project Arcade and newbie links but I can't find the answer.
I have my control panel figured out and I want to make wiring "as simple as possible"
This is what I have
      (2)8 way joysticks with (6) pushbuttons on each stick
      (1)Happs Trackball with (3) pushbuttons and USB/PS-2 conect.
      (4)player/coin up buttons,(1)pause and (1)exit button
I will be using the I-Pac to interface pushbuttons and joysticks into PS-2 port
and will plug in the Happs Trackball into USB.
Will this work? Will the I-PAC and track ball work indeependantly?
Or do you need to connect the trackball into the I-PAC system?
I want to use the trackball for navigation on windows and use it for gaming.
Any advice/links appreciated!
- r e n d e r -
  • Last login:September 08, 2008, 02:10:09 am
    • Plastic Art
Re:I-PAC AND HAPPS TRACKBALL INTERFACE
« Reply #1 on: September 23, 2004, 01:33:36 pm »
You got it.  The trackball will show up like a normal mouse.
Hoagie_one
  • Um....whats a cabinet
« Reply #2 on: September 23, 2004, 01:55:44 pm »
a standard Ipac doesnt support trackballs or spinners, you need an optipac, or minipac with optic harness
TRIBOY
« Reply #3 on: September 23, 2004, 03:36:15 pm »
Thats my question? Do I need to tie the trackball into the I-Pac with an optipac?
Because I want to order the Trackball with a USB/PS2 connection, which I am assuming you can just plug into the computer?
Hoagie_one
« Reply #4 on: September 23, 2004, 03:51:01 pm »
TRY TO GET THE PS2\USB VERSIONS.  THEY WILL SAVE YOU MONEY BUYING AN OPTIPAC.
UNLESS YOU WANT MULTIPLE TRACKBALLS  AND SPINNERS
I BELIEVE YOU CAN JUST BUY AN ADAPTER FROM OSCARCONTROLS TO ATTACH A NORMAL HAPPS TRACKBALL
whammoed
  • Last login:Today at 09:05:02 am
  • Crack don't smoke itself
    • NiceMite
« Reply #5 on: September 23, 2004, 03:56:54 pm »
If you buy the happs trackball with usb/ps2 interface you do not need an optipac.  Plugs in the same way a regular mouse would.  This is exactly what I did on my first cab.  Easy.
« Reply #6 on: September 24, 2004, 06:46:03 am »
(from other thread)
That is fine, they are totally separate entities.
The IPAC is purely a keyboard encoder, so use that for all your digital inputs (as you correctly plan to do).  As far as Windows is concerned the IPAC is just a keyboard.
The trackball interface will make the trackball appear as a mouse in Windows, so you can use this for Window itself, and MAME / anything else which normally uses mouse input.
