Main > Main Forum
Applying a CPO......Use the "Wet" method???
spriggy:
Try 'Windex'.
Minwah:
--- Quote from: spriggy on September 21, 2004, 08:48:29 am ---Try 'Windex'.
What is Windex? Is it just a window cleaning solution?
mp2526:
Yes, the blue window cleaning solution here in the States.
koolmoecraig:
Yes, I used windex on the side art. It worked great, but this hairspray idea sounds intriguing. The control panel gets alot more contact than the side art.
Wade:
Windex is commonly used but it isn't ideal. It breaks down the adhesives. If you don't believe me or aren't sure, then on a scrap piece of your artwork, peel off the backing and spray it down with Windex. Then rub your fingers on it. You'll find the adhesive usually just kinda washes off...
Soapy water would probably be the best thing, or do it dry if the artwork isn't too large. I've always done it dry and haven't had any ripples or bubbles or bad positioning. Just be careful!
Wade
