Author Topic: Question - Adding a Spinner (Connect through Trackball?)  (Read 947 times)
njchan
  • Last login:January 17, 2017, 05:09:21 pm
« on: September 20, 2004, 10:02:11 pm »
I bought the following from Happ ...
http://www.happcontrols.com/trackballs/565600xx.htm
(2-1/4" TRACKBALL WITH USB AND PS/2 INTERFACE)
If I bought a spinner, is there anyway to connect the spinner to this interface board as well? ... or would I need to get another package all together.  i.e. something like this ...
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=5124512390
Any help would be appreciated.
Lilwolf
Re:Question - Adding a Spinner (Connect through Trackball?)
« Reply #1 on: September 21, 2004, 12:20:07 pm »
Probably not.
You might be able to do something, but I think it would be inefficient.
Instead...
goto oscarcontrols.  Pick your favorite spinner, your favorite knob... Then order a prehacked usb mouse.  They are 9 bucks and SUPER easy and a small percentage of a new spinner will cost.
but the troubles.
Well, two usbs work great on windows...  But they both work at the same time.  So if you hit the spinner a little when using the trackball (or other way around) it will combine the values sent.
solutionsish.
use AnalogMame+ (or NoNameMame) which seperate them.  And all spinner games you setup to mouse 1 and trackball games to mouse 2 (or whatever they are setup as).
But both builds are usually a few versions old.  Not a big deal... just requires you to keep more then one version of mame installed on your cabinet.
« Reply #2 on: September 21, 2004, 02:13:04 pm »
Quite possibly not a problem tho, as long are you remember this fact when playing (ie don't touch the control you're not using)...
Perhaps more of a problem if you have friends/family who also know this happens, and enjoy ruining your game!  :(
njchan
« Reply #3 on: September 21, 2004, 02:50:28 pm »
the current Trackball from Happs only has a PS/2 interface though ... how does a PS/2 & a USB work together?
Lilwolf
« Reply #4 on: September 21, 2004, 03:00:27 pm »
btw, this is why I ended up rewiring my first control panel that had the 1st player 8way and the 4way controller hooked to the same inputs.
When playing streetfighter with a friend of mine... he would grab the 4 way EVERY time I was about to get him.
But after removing that feature... Now he goes after me.  Your about to do a super upper cut special super move because they are dizzy... and wham!  shoulder tackle from the side!
« Reply #5 on: September 21, 2004, 04:16:41 pm »
LMAO!  :D
BarontheFirst
  • Last login:April 11, 2023, 07:42:07 pm
  • Locked out of the gameroom again!
« Reply #6 on: September 21, 2004, 05:27:36 pm »
Just curious but is an opti-pac out of your price range? It will solve your problem.
