Author Topic: painting the inside of cabinet  (Read 1042 times)
deadmoney5
  • Last login:February 03, 2020, 11:02:02 pm
  • I don't feel tardy
« on: September 18, 2004, 05:03:59 pm »
I am painting my cabinet black and am wondering if it is even necessary to use primer on the parts that will only be on the inside of the cabinet..
I just plan on using one coat of black on those parts too
I assume this will look ok since you wont see those parts much anyways?
GGKoul
  • Cheesecake Apprentice
Re:painting the inside of cabinet
« Reply #1 on: September 18, 2004, 05:30:24 pm »
No primer is required.
spystyle
« Reply #2 on: September 18, 2004, 08:21:59 pm »
I prime and paint every inch of my cabs, inside and out, top and bottom, weather it is ever seen or not it will help to seal and protect the wood.
Dig it?
Craig
« Last Edit: December 09, 2006, 12:24:53 pm by spystyle »
sonicflood
  • Last login:August 19, 2005, 11:22:40 pm
« Reply #3 on: September 18, 2004, 09:08:58 pm »
I painted the lower portion (below control panel) with grey primer & the upper portion (above control panel) flat black.
It makes it easier to see the components in the bottom of the cabinet.
"Oh, you should never never doubt what nobody is sure about." -Willy Wonka
daywane
  • Online Online
  • Last login:Today at 04:45:59 pm
  • GRRRR!
« Reply #4 on: September 18, 2004, 09:39:24 pm »
My arcades are made from old ones
a roby robo cab
nintendo vs uni
and a old base ball arcade
all from old school arcades . Thay are not painted inside and have lasted 20+ years.
SirPoonga
  • Puck'em Up
  • Last login:April 12, 2023, 09:22:35 pm
  • The Bears Still Suck!
« Reply #5 on: September 18, 2004, 09:46:35 pm »
Some don't :)
It all depends on if you are in a regularly humid environment or not.
daywane
  • Online Online
  • GRRRR!
« Reply #6 on: September 18, 2004, 11:57:09 pm »
Some don't :)
true. but it is humid in KY
« Last Edit: September 19, 2004, 12:00:21 am by daywane »
TalkingOctopus
  • Last login:September 06, 2023, 03:39:02 am
    • My Arcade
« Reply #7 on: September 19, 2004, 12:41:56 am »
I used primer on the inside of the cabinet to seal the wood.  I did not paint the inside, because paint is somewhat expensive while primer is dirt cheap so the less surface area you need to paint the better.  I did 2 coats of primer on both the inside and outside of my cab.
« Reply #8 on: September 20, 2004, 07:24:07 am »
I would always paint all exposed wood (esp. MDF / chipboard).  Better safe than sorry in my book.  I'd recommend a topcoat over primer too, in case anything ever gets spilled on it (primer will soak it up).
I painted the inside of mine light grey for the same reason as sonicflood, it makes it easier to see (it's pretty dark inside!): http://www.arcadecontrols.org/yabbse/index.php?board=10;action=display;threadid=18812
