Author Topic: Anyone get T2 to work with act-labs gun?  (Read 2915 times)
menace
  • Last login:September 18, 2023, 10:57:06 am
« on: September 15, 2004, 04:37:54 pm »
I followed the act-labs site directions for setup but all i got was wildly inaccurate shots--I'd be interested in hearing how it could be done. (i'm running mamewah with xp)
whammoed
  • Last login:Yesterday at 09:05:02 am
  • Crack don't smoke itself
    • NiceMite
Re:Anyone get T2 to work with act-labs gun?
« Reply #1 on: September 15, 2004, 04:41:16 pm »
I thought T2 is an analog stick with a gun attached, not a light gun game?  could be wrong
the3eyedblindman
  • Last login:November 17, 2006, 03:00:06 pm
  • Soon: 4 Player Mame and Scratch Built Moonwalker.
« Reply #2 on: September 15, 2004, 05:05:01 pm »
it has 2 mounted guns that act like giant joysticks, but T2 would be better to play with an act labs gun, so hopefully theres a way, thats onea the shotting games i was looking forward to with my act labs gun... ???
Coming soon: 4 player mame cab and Scratch built Moonwalker....Hall of Fame, here I come!
clanggedin
  • Last login:July 02, 2012, 11:08:55 pm
  • O'DOYLE RULES!!!
« Reply #3 on: September 15, 2004, 05:23:04 pm »
I have it running perfectly with 2 guns. First of all you need to disable the guns in mame.ini and calibrate with the mouse. 0,0  128,128  255,255
After calibration is done then just calibrate the guns normally and you are ready to go. You have to done the same with Revolutiuon X.
The only problem with the game is that you cannot hold down the trigger and move the gun back and forth, so your trigger finger gets pretty tired after a while.
BTW,  I'm running mamewah with xp also. Make sure you are using mame analog+.
« Last Edit: September 15, 2004, 05:24:42 pm by clanggedin »
menace
« Reply #4 on: September 15, 2004, 09:15:31 pm »
hmmm--I disabled the guns in mame.ini but i couldn't get mouse support to work--I tried configuring player 1 to mouse 4 (the real mouse) and it still wouldn't take any input--it didn't work with  the keys either.  I wouldn't normally try this hard but when i calibrate, it always gives me false hope by saying calibration successful--damn you arnie!
the3eyedblindman
« Reply #5 on: September 15, 2004, 09:38:41 pm »
For all of you that play T2 in your cabs, do u use a joystick or gun?
Silver
  • Last login:February 17, 2024, 10:29:00 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #6 on: September 16, 2004, 03:24:38 am »
Is this a limitation of the act-labs gun only sending 1 pulse per trigger pull, or is there a config way around this?
Lilwolf
« Reply #7 on: September 16, 2004, 07:38:14 am »
The only way I've been able to play is to use the second button as a fire also.
Then hold that button for machine gun, and the first to move it.
It still sucks though.
Silver
    • Mods'n'Mods
« Reply #8 on: September 16, 2004, 10:49:44 am »
ah i gotcha.... so what we want is a way of (optionally) making the gun auto-fire - white pulses and all. Is this an act-labs driver thing?
Lilwolf
« Reply #9 on: September 16, 2004, 11:14:56 am »
better solution (that I ended up doing) is buying 2 t2 guns.  I now use them more then my lightgun!
Ok, I REALLY use it more because I bought a real arcade gun and am 1/2 of hacking my actlabs lightgun into the arcade gun....  After that, I might use that more often...
But getting the real guns is GREAT... also fun for 1 player john who style playing.
clanggedin
  • O'DOYLE RULES!!!
« Reply #10 on: September 16, 2004, 01:53:41 pm »
OH MAN!!!! I told you wrong... I'm a retard!
Use the Joysticks to calibrate, not the mouse. I'm sooooo stupid.
When you disable guns the joysticks can be used to calibrate in T2.
Sorry for the mis-information
« Last Edit: September 16, 2004, 01:54:56 pm by clanggedin »
jelwell
  • Last login:December 24, 2014, 03:47:21 pm
Re: Anyone get T2 to work with act-labs gun?
« Reply #11 on: March 24, 2005, 02:03:01 pm »
I know this is probably 5 months too late, but I was searching around the forums and here's your solution.
Download the Terminator 2 NVRAM file here:
http://www.retroblast.com/files.html
Joseph Elwell.
the3eyedblindman
« Reply #12 on: March 24, 2005, 11:42:06 pm »
Press F2 after starting T2, go to calibrate guns, use mouse to correctly calibrate, then restart game and wallah! your gun will work. Same with Revolution X.
1UP
  • Token Junkie
    • 1UPArcade
« Reply #13 on: March 26, 2005, 05:12:13 am »
I tried T2 with lightguns.  You can get it to work with autofire mode, but you get a headache pretty quick with all the flashing.  Positional is still the best way to go for machine gun games, until someone comes up with a gun that doesn't rely on screen flashing.
My other job...
the3eyedblindman
« Reply #14 on: March 26, 2005, 03:00:34 pm »
When you are playing you barely notice the flashing.
