Main > Main Forum
Anyone get T2 to work with act-labs gun?
clanggedin:
OH MAN!!!! I told you wrong... I'm a retard!
Use the Joysticks to calibrate, not the mouse. I'm sooooo stupid.
When you disable guns the joysticks can be used to calibrate in T2.
Sorry for the mis-information
jelwell:
I know this is probably 5 months too late, but I was searching around the forums and here's your solution.
Download the Terminator 2 NVRAM file here:
http://www.retroblast.com/files.html
Joseph Elwell.
the3eyedblindman:
Press F2 after starting T2, go to calibrate guns, use mouse to correctly calibrate, then restart game and wallah! your gun will work. Same with Revolution X.
1UP:
I tried T2 with lightguns. You can get it to work with autofire mode, but you get a headache pretty quick with all the flashing. Positional is still the best way to go for machine gun games, until someone comes up with a gun that doesn't rely on screen flashing.
the3eyedblindman:
When you are playing you barely notice the flashing.
