Main > Main Forum
Waht's your boot screen looks like ?
missioncontrol:
I like your 2nd boot screen thenasty where did you get it?
Thenasty:
got some pics of here and check the links. Just put one and two together.
simplygriff:
--- Quote from: Darkstalker on September 16, 2004, 02:15:19 pm ---
--- Quote from: simplygriff on September 16, 2004, 09:30:42 am ---
--- Quote from: Darkstalker on September 15, 2004, 05:51:01 pm ---
--- Quote ---I wish I could get rid of the damn 'welcome', 'loading your personal settings' and 'saving your settings' screens tho - anyone done this?
Turn off fast user switching, and setup an automatic login for a user. This will skip the Fisher Price welcome screens and take you straight into WinXP.
WHere do I turn off fast user switching?
-G
Control Panel, in the User Accounts section. Select "Change the way Users Log On and Off", and it's pretty obvious from there.
Thank You. My brain farted when I asked this question. :-[ :P ::) :P :-[
MrBond:
Pretty sure I nabbed this off of http://www.themexp.org/
They have a nice way of setting up new boot screens without screwing your system over. You basically add a line to c:\boot.ini, and to see if the boot works, windows gives you a list at bootup to choose which bootup screen you want. If everything works as planned, you delete the original line and keep the new one...I found it straight forward.
MrBond:
The directions I followed are attached (rename bootinstruct.png to bootinstruct.txt)
