Author Topic: Where to get 1/16" slot cutter router bit????  (Read 2085 times)
megashock5
  • Last login:May 19, 2015, 06:51:16 am
« on: September 11, 2004, 01:24:17 pm »
Hello, I'm building a cabinet from the Project Arcade book. It says to use a 3/32" slot cutter router bit, but both tmolding.com and groovygamergear say that their molding uses 1/16".
The problem is I can find slot cutter bits anywhere around here. The book says there is a list of sources for the bit on the accompanying CD, but the list is all for controls - no listing for router bits like it claims.
Any suggestions? Where have you guys found these?
thanks!
pointdablame
  • Last login:November 09, 2023, 09:11:07 pm
Re:Where to get 1/16" slot cutter router bit????
« Reply #1 on: September 11, 2004, 02:08:42 pm »
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_slot.html
3 wing slot cutter.   width of cut - 1/16".   Buy the complet set unless you have the arbor and bearing already.
first off your and idiot
Tailgunner
« Reply #2 on: September 11, 2004, 07:37:28 pm »
I ordered mine through Lowe's. They carry Bosch router bits and can get the slot cutters. I ordered both a 1/16" and a 5/32" cutter and a single arbor. So far I've used the 5/32" more because the T-molding I have fits it better.
okmike87
  • Last login:April 25, 2019, 01:20:51 pm
  • I like them biscuits and mustard!
« Reply #3 on: September 11, 2004, 09:54:29 pm »
Has anyone had any experience with the t-molding from www.dreamarcades.com?
If so, what size slot cutter should I use to install it?
Mike
megashock5
« Reply #4 on: September 11, 2004, 10:49:20 pm »
Tailgunner, do you remember how much the 1/16" slot cutter was through Lowes? I have a couple fairly close.
The link in the post before yours has them for $16 including for the whole thing and $12 for just the blade part.
thanks!
[derek]
  • Last login:July 06, 2006, 10:48:51 pm
  • Small hands, smells of cabbage.
    • Gallery of my progress pictures
« Reply #5 on: September 12, 2004, 02:23:54 am »
I ordered mine through MLCS. Quality is pretty good, price is king with them.  I can also say that the shipping time was excellent. Two days from order to door. I think they are in Ohio (I'm in CT).  I also had a goof up on my order, they called me, and I asked a few questions - all answered promptly.  Great company.
I tried ordering the bit first from  HP and Lowes, both failed horribly.  Of course most of the tool folks seem to be a tad too busy to take orders for me (on tools) when I go there.
- derek
Tailgunner
« Reply #6 on: September 12, 2004, 04:16:50 am »
thanks!
As I remember I paid about $40 for a 1/2" shank arbor and both blades. MLCS would be $38 for the same deal, seems pretty comparable to me. I didn't have the ordering issues Derek had, but then I deal with them a lot and know who to talk to at my store. I ordered on monday and had it by the following friday. YMMV. ;)
megashock5
« Reply #7 on: September 13, 2004, 09:36:11 am »
I went ahead and ordered the 1/16" set from MLCS. Seems like the best price and free shipping.
Thanks to everyone for the info!
goofy
  • Last login:January 03, 2005, 01:11:10 am
« Reply #8 on: September 13, 2004, 06:22:19 pm »
I assume you ordered part #5341 for $16 with free shipping.
From the knowledgable crowd, is this all that is needed to cut the T-molding slots or are there other pieces required as well.
A couple posts back, the guy mentioned $36 was needed.
Tailgunner
« Reply #9 on: September 13, 2004, 07:02:23 pm »
The $16 deal should be all you need if your T-molding fits a 1/16" slot.  Mine ended up needing a 5/32" slot, so ordering the other size cutter blade ended up saving me time and extra shipping charges.  In a pinch you could offset a the cutter a little, make a pass, then offset it the other way to end up with a 5/32" slot if you needed it.
I did screw up the math, MCLS sells the cutters for $16 with an arbor and $12 without. Buying both sizes through them would be $28, not $38.
goofy
« Reply #10 on: September 13, 2004, 07:19:52 pm »
Cool, thanks. I appreciate the help. That's a pretty good deal and the free shipping is excellent.
  • Last login:Yesterday at 04:31:28 pm
« Reply #11 on: September 20, 2004, 11:48:18 pm »
This is great.  I'm ordering.  Thanks!
