Author Topic: volume and ipac?  (Read 3291 times)
mcdo15
  • Last login:February 16, 2008, 01:49:17 pm
  • why can't i make up my mind
volume and ipac?
« on: September 08, 2004, 11:49:54 am »
is there a way to control volume though ipac connection?  maybe like a volume hack to turn up or down volume (sought like the microsoft keyboard internet pro?)
thanks
Bgnome
  • Last login:January 10, 2005, 04:05:16 pm
  • Who's da gnome?
Re:volume and ipac?
« Reply #1 on: September 08, 2004, 12:21:29 pm »
hmm.. i think he may be asking about the "i-pac", not the ipod.  hence the whole "build your own arcade controls" motif..
anyhow, as i dont have an ipac or something similar, all i can offer is conjecture.  have you tried programming it with winipac ipd?  since the "volume" buttons on a windows multimedia keyboard do send actual keycodes, then i dont see why the ipac couldnt.  however, this is only limited to windows as far as i know so would not be helpful for those running dos/linux setups.  another drawback i can think of is in ps/2 mode, the ipac does not support key repeats on all inputs so you may end up tapping the volume button a whole lot instead of being able to hold it down.  personally, i am planning on going with an actual volume knob ala oscar's inline hack.  i prefer to have a real hardware solution rather than take up 2 coveted inputs for a "soft" solution..
mcdo15
Re:volume and ipac?
« Reply #2 on: September 08, 2004, 12:36:15 pm »
well, im using usb ipac....i have a knob but it would be not located where i wanted to...so i figure i'll use shift command on my 3 admin buttons to do double work.  just a thought...it ok that i press a button for 1 bar changing the voulme.  i havnt hooked it up yet...just getting a headstart into it...
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re:volume and ipac?
« Reply #3 on: September 08, 2004, 01:39:07 pm »
Ummm I may be way off here but it sounds like you need to just activate "tab" or "~" to bring up MAME's volume setting. Then you would use your joystick left/right....
NO MORE!!
Goz
  • KOTA
  • Last login:September 03, 2020, 02:23:18 am
Re:volume and ipac?
« Reply #4 on: September 08, 2004, 01:48:55 pm »
There is another way. You can use a free application such as HotKeycontrol XP Which will let you set any keys to values you want.
Hope this helps
mcdo15
Re:volume and ipac?
« Reply #5 on: September 08, 2004, 02:28:22 pm »
both of those post are great..i will see which is better...thanks
reebboy
  • Last login:December 12, 2005, 01:34:53 am
  • Now its time for some serious insanity!!!
Re:volume and ipac?
« Reply #6 on: September 09, 2004, 12:52:18 am »
Are there any other applications like "Hot key control" for win 98?? I have a same situation and it sounds like a possible solution.
That works great for Mame but not for the other emulators. :-*
Dude!!! Where's my game.....
Goz
  • KOTA
Re:volume and ipac?
« Reply #7 on: September 09, 2004, 02:00:49 am »
Here's one that is 98 friendly called SOund Control Also a freeware package.
Hope it helps
-Goz
