Author Topic: Mamemarquees.com PROBLEM *******  (Read 792 times)
koolmoecraig
    • My Intervention
« on: September 05, 2004, 03:43:16 am »
I sent my CPO design to Scott to get printed, and here is the problem.
The file is in Adobe Illustrator CS. He has Illustrator 10 and the file will not open.
He wanted me to convert the file to Photoshop file, but doesn't this reduce the quality over Illustrator? Am I going overboard in wanting to keep in Illustrator format for printing?
I want the highest possible quality with NO COMPROMISE. Will this be a compromise?
Thanks,
Craig
Snarbald
  • Last login:September 27, 2006, 10:38:25 pm
  • I hate pants!
    • snarbald.com
Re:Mamemarquees.com PROBLEM *******
« Reply #1 on: September 05, 2004, 03:48:15 am »
how about saving as an eps file? You at least used to be able to save for older versions of illistrator that way.
Zapper
  • Last login:October 07, 2006, 10:26:01 pm
  • The enemy's gate is down
« Reply #2 on: September 05, 2004, 04:22:31 am »
I do a lot of my control panel and marquee designing in Illustrator then export the art to Photoshop at 300 dpi cmyk and add more effects to it. I wouldn't worry about bad quality unless you're making some large side art. If you were going to have your control panel screen printed to an overlay you might want vector art though.
"Three warps to the Bugger homeworld"
mahuti
  • Last login:March 02, 2022, 09:51:19 pm
« Reply #3 on: September 05, 2004, 09:16:57 am »
Can't you just save the file down?
I do it all the time.
clanggedin
  • Last login:July 02, 2012, 11:08:55 pm
  • O'DOYLE RULES!!!
« Reply #4 on: September 05, 2004, 11:51:46 am »
You can save it as a PDF if nothing else needs to be done and he should be able to print from it.
DougHillman
  • Last login:September 13, 2004, 07:39:18 pm
« Reply #5 on: September 05, 2004, 02:08:59 pm »
"File" "Export" "Illustrator Legacy"
If you can't be a good example at least try to be a horrible reminder.
