Author Topic: Super disassembly problem  (Read 1132 times)
itismejs
  • Last login:February 29, 2012, 05:25:43 pm
« on: September 02, 2004, 12:55:51 pm »
I just got some supers in a trade but they came assembeled. I was able to ge the clip off as well as the plastic thing on the shaft.  Now there is a metal round thing (for lack of better words) That I think is holding the shaft in. How do I get it out?
pointdablame
  • Last login:November 09, 2023, 09:11:07 pm
Re:Super disassembly problem
« Reply #1 on: September 02, 2004, 01:23:25 pm »
I'm not sure what you mean exactly as I haven't disassembled a Super, but this may help.
http://www.happcontrols.com/joysticks/super_joy_e.htm
first off your and idiot
neuromancer
  • Last login:May 10, 2006, 04:26:57 pm
  • Can I Play?
« Reply #2 on: September 02, 2004, 01:25:39 pm »
Get what out of what?
If you take off the clip, the handle pulls out of the square black part. There is an actuator and another black plastic part on the shaft, and a dust cover.
That's it. If you're trying to take the knob off the shaft, it doesn't.
You can view an exploded diagram on happcontrols.com
Bob
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #3 on: September 02, 2004, 01:31:12 pm »
If the shaft won't just slide out the top, it could be rust to the washer inside... try tapping the bottom of the shaft with a hammer...
NO MORE!!
itismejs
« Reply #4 on: September 02, 2004, 01:42:02 pm »
96412100 is keeping the shaft from comming off.
Thenasty
  • Trade Count: (+17)
  • Last login:Today at 02:01:34 pm
« Reply #5 on: September 02, 2004, 01:52:28 pm »
sounds like the shaft is rusted in place. Take the bottom base out so you have more access to holding in palce while twisting the shaft around to loosen it up.
Free VGA Breakout Cable
itismejs
« Reply #6 on: September 02, 2004, 02:09:02 pm »
whammoed
  • Last login:Today at 09:05:02 am
  • Crack don't smoke itself
    • NiceMite
« Reply #7 on: September 02, 2004, 03:05:52 pm »
Yep, its stuck on there...try harder.  It is meant to just slide off.
itismejs
« Reply #8 on: September 02, 2004, 03:12:26 pm »
I got it but OWWWWWWWWW. That hurt :0.
