Author Topic: X-Arcade....w/trackball???  (Read 1300 times)
MAME nut
  • Last login:March 18, 2024, 12:33:01 am
« on: August 26, 2004, 02:36:13 pm »
I picked up an X-Arcade 2-player controller real cheap.  After some thought, I wish I could incorporate a trackball into it.
SO.........is it possible to add one and tie it into the existing control wiring??  HELP..........
Evil Otto
  • Last login:March 20, 2007, 09:19:05 pm
Re:X-Arcade....w/trackball???
« Reply #1 on: August 26, 2004, 04:19:13 pm »
Hello,
I am not an expert here, I don't think there is any way to tie into the existing controls.  You would have to cut area for a trackball that would fit and then just run trackball wires (Ps/2, usb or whatever wires connect to optipac if you have one) out of x-arcade to your pc.  The trackball is contolled independent of the x-arcade encoder.
Hope that helps.
MAME nut
« Reply #2 on: August 26, 2004, 05:17:24 pm »
I'm not sure if I understand.....are you saying that I could buy a USB trackball, cut it into the control panel, but connect it directly to the computers USB slot??
mcdo15
  • Last login:February 16, 2008, 01:49:17 pm
  • why can't i make up my mind
« Reply #3 on: August 26, 2004, 05:57:09 pm »
that would work
paigeoliver
  • Awesome face!
« Reply #4 on: August 26, 2004, 06:11:12 pm »
What made you think a USB trackball would stop working if you placed it inside an X-arcade?
There is no way to make it work with the existing X-arcade wiring as it is totally the wrong kind of thing for that.
MAME nut
« Reply #5 on: August 27, 2004, 09:22:02 am »
I wasn't sure if I needed some type of interface between the USB trackball and the computer's USB jack???   :-\ :-\ :-\
I'm also not sure how to "program" the tracball to work on certain games...........
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #6 on: August 27, 2004, 10:10:08 am »
Super newbie!
You just said it's a USB Trackball.  U... S... B...
Therefore...... It must ALREADY have a cable to connect it to USB right?
AND If it was made for the PC, then golly, it must already work, no? USB trackballs get recognized as a mouse. No need to "program" the games.
~Ray
NO MORE!!
zaphod
  • Last login:September 04, 2012, 11:11:38 am
    • ArcadeCab.com
« Reply #7 on: August 27, 2004, 10:33:30 am »
A 3" arcade trackball will not fit in the little X-arcade.  However, I have seen examples of USB mice hacked into the panel.  Seems like there was an example here a number of months ago.
fredster
  • It's all good!
« Reply #8 on: August 27, 2004, 11:07:24 am »
The Xarcade looks pretty small to do that.
It's a hassle to rip that control unit out too.  It's got a bunch of special wires in about 6 separate circuits.
I used it on my first mame machine, just the control, and the one I have just uses the PS/2.
