Author Topic: Question to all UA2 Builders.  (Read 1290 times)
the3eyedblindman
  • Last login:November 17, 2006, 03:00:06 pm
  • Soon: 4 Player Mame and Scratch Built Moonwalker.
« on: August 24, 2004, 08:59:35 pm »
I am planning my control panel soon, it will be a 4 player on an ultimate arcade 2 cab. What I need to know is, from the outside edges of the cabinet bottom  (UA2) how far from the outside edges does the control panel stick out each way, I am not looking for a specific answer, as all are alittle different, Im just looking for a rough estimate to start with. The width of the cabinet is 28 and 1/2 inches, what is a good estimate in inches on how far to make the control panel stick out  on each side?
Coming soon: 4 player mame cab and Scratch built Moonwalker....Hall of Fame, here I come!
JAMMA Guy
  • Last login:June 18, 2004, 01:14:07 am
  • PCB's Are Better!
Re:Question to all UA2 Builders.
« Reply #1 on: August 24, 2004, 10:13:10 pm »
10 - 3/4" on each side  :) (personally I think its sized to perfection ... it's smaller than the SlikStik "Quad"  ;) )
the3eyedblindman
« Reply #2 on: August 24, 2004, 10:20:56 pm »
Did you do a UA2 4 player? if so will u post a pic of ur control panel?
MiKman
  • Last login:March 25, 2018, 12:28:45 pm
  • Blah
« Reply #3 on: August 24, 2004, 10:39:12 pm »
you've seen mine, although it's only a 2 player franken panel it sticks out only 7 1/2 inches on either side.
the3eyedblindman
« Reply #4 on: August 24, 2004, 11:33:21 pm »
Ill probably go with 9 inches, right in between your 2 answers.
bwillis614
  • Last login:August 24, 2004, 10:38:57 am
« Reply #5 on: August 25, 2004, 11:41:33 am »
http://www.slam-tilt.com/pinball/gallery/view_album.php?set_albumName=album13&page=3
I'll measure it tonight.
I'm going to be rebuilding mine.  27" screen that close is too much.  I'm going to build it further out, and widen it quite a bit.  I don't like the angle of players 3 and 4, hard to play total carnage, smash tv, other two joystick games.
Sylentwulf
  • Last login:October 05, 2009, 09:13:35 am
    • The Electric Quarter
« Reply #6 on: August 25, 2004, 07:21:34 pm »
I have a decent sized 2 player panel with 4-way and trackball, and it only sticks out about 2-3 inches on either side on a 27" wide cab.
BYOAC users get 5% off with coupon code byoac5
