Author Topic: RAN INTO A HUGE PROBLEM!  (Read 3703 times)
the3eyedblindman
  • Last login:November 17, 2006, 03:00:06 pm
  • Soon: 4 Player Mame and Scratch Built Moonwalker.
« on: August 22, 2004, 08:39:55 pm »
I bought a beautiful over under coin door that looks great, and it just so happens its about 1/4 inches shorter than the door its going on! :( What am i going to do? i cant rebuilt the whole thing, and im afraid the mdf will just crack in half with only a tiny peice of wood holding it together (the coin door will basically cut the wood in half) what am i going to do, i really like the over under door better than a normal coin door.
Coming soon: 4 player mame cab and Scratch built Moonwalker....Hall of Fame, here I come!
Apollo
    • Eight Bells
Re:RAN INTO A HUGE PROBLEM!
« Reply #1 on: August 22, 2004, 08:57:19 pm »
Sell it get a new one that fits. Not much advice I know but sounds like your only option.
the3eyedblindman
« Reply #2 on: August 22, 2004, 09:00:59 pm »
i dont know, the one i have looks great, i restored it to new condition, made new coin button stickers for it, and  i wanted an overunder door, not a normal one, i really dont want "selling this one" to be an option.
paigeoliver
  • Awesome face!
« Reply #3 on: August 22, 2004, 09:08:38 pm »
Looks like you are going to simply have to get/use another door.
the3eyedblindman
« Reply #4 on: August 22, 2004, 09:13:58 pm »
id rebuild the whole thing before buying another door, theres gotta be somehow to get this to work.
photorock
  • Last login:March 07, 2006, 08:37:03 am
  • Goofy Newfy!
« Reply #5 on: August 22, 2004, 09:28:51 pm »
          How about placing a sheet of metal behind the door with screws or bolts and then cutting out the opening for the coin door. That sould give the door the support it needs.
the3eyedblindman
« Reply #6 on: August 22, 2004, 09:30:16 pm »
Thanks photorock, its those kind of thoughts i need, ill try that, any other ideas?
pocketbikez
  • Last login:January 16, 2005, 06:23:36 pm
  • INSERT COINS
    • my arcade cabinets
« Reply #7 on: August 22, 2004, 09:32:00 pm »
maybe some metal bracing or an interior frame to strengthen the front wood piece.
would the coindoor look funny installed with such a small amount of clearance at the top and bottom?
the3eyedblindman
« Reply #8 on: August 22, 2004, 09:35:39 pm »
I wouldnt think so, considering the cabinet and the coindoor are black....but i dont know.
photorock
  • Goofy Newfy!
« Reply #9 on: August 22, 2004, 09:51:37 pm »
        Hey every now and then the light goes on and on occasion it works.
old school gamer
  • Last login:December 22, 2006, 02:20:28 pm
  • Woodworking Genius, computer illiterate!
    • my homepage
« Reply #10 on: August 22, 2004, 10:06:21 pm »
Dont underestimate the power of wood glue. If you are a quarter inch to big ,cut a piece of MDF and nail and glue it to take up the space,then fill the line let over with putty or bondo.Wood glue is AMAZINGLY STRONG. If you glue 2 pieces of wood together and let it dry,then try to sepperate it.... you will destroy the wood before it separates at the joint the glue was applied to. Again,wood glue is very strong. OSG
My tag line was inappropriate for a family oriented site. It has been changed by saint.<-- THATS better than anything I could have come up with!!!!!!! Thanks Saint!!!-
the3eyedblindman
« Reply #11 on: August 22, 2004, 10:12:52 pm »
theres really not alotta room to add wood tho, its the floor, and then the start of th control panel, where would i add it, i think you thought i meant my wood was a quarter inch to thin or something, but thanks for the help.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #12 on: August 22, 2004, 10:18:32 pm »
Add a "base" to your cab?
NO MORE!!
the3eyedblindman
« Reply #13 on: August 22, 2004, 10:24:44 pm »
already have one, and wheels.
paigeoliver
  • Awesome face!
« Reply #14 on: August 22, 2004, 10:24:56 pm »
Why is your control panel starting 2 feet from the floor? Midget cab?
the3eyedblindman
« Reply #15 on: August 22, 2004, 10:30:48 pm »
its a ultimate arcade 2 cab, it goes up from the floor, then like goes out, and up again, then the control panel sits on top of that.
paigeoliver
  • Awesome face!
« Reply #16 on: August 22, 2004, 11:33:36 pm »
Oh, why do people continue to build those, it looks very little like any actual machine ever made.
You could put the door on the side.
MinerAl
  • Last login:March 21, 2023, 07:11:28 am
  • duck
« Reply #17 on: August 22, 2004, 11:41:44 pm »
Here's a wacky plan...
Take the over/under to a metal shop and have them section about an inch out of the "under" half.  That door is only to get the coin tub out, so as long as you similarly modify your coin tub, it shouldn't matter how big it is.
If you wanted to, you really could have the entire "under" part removed, and have a small coin door, and access the tub like you would with a midway or pinball coindoor.
MiKman
  • Last login:March 25, 2018, 12:28:45 pm
  • Blah
« Reply #18 on: August 23, 2004, 12:22:04 am »
I built the ultimate arcade II as well and I put in an over under coin door.  Like you I though aww crap it's longer than the space provided...  but it's not that bad the outer frame of the coin door goes right from the very bottom of the cabinet and I had to cut some of the angled upper portion out to 'tuck' it under but it fits and it's so nice that the coin bucket slides right in on the bottom and fits like it should.  I'll take some pics and post em. It looks real good IMHO.
« Last Edit: August 23, 2004, 12:35:39 am by MiKman »
MiKman
  • Blah
« Reply #19 on: August 23, 2004, 12:28:24 am »
True it doesn't look like a 'real' arcade cabinet, but it is stylish and if we were building real arcade cabinets then what the heck are they doing running 5000 Games with keyboards and computers in them running windblows?
MiKman
  • Blah
« Reply #20 on: August 23, 2004, 12:37:33 am »
wow wacky that first picture I did not have, I have no idea where that came from. weird andyhow here is how I handled the over/under coindoor on my UAII cabinet.
pointdablame
  • Last login:November 09, 2023, 09:11:07 pm
« Reply #21 on: August 23, 2004, 01:42:45 am »
I just have to ask..... you completely stripped and restored a coin door without once putting it next to the cab to size it up?
first off your and idiot
Goz
  • KOTA
  • Last login:September 03, 2020, 02:23:18 am
« Reply #22 on: August 23, 2004, 02:05:50 am »
If you've read any of his posts, you know exactly what he did.
Doh!
-Goz
SirPeale
  • Green Mountain Man
« Reply #23 on: August 23, 2004, 10:23:33 am »
My suggestion would be to sell it.  Yes, you put a lot of work into it, but it won't fit.  Would you wear a pair of pants that you made if they were two inches too small?
Post some pictures, I'm sure if it's as nice as you say you can get some good money for it.
Then, get a Williams style door.  That *will* fit.  I'm working on some now, but at the rate I'm working on it, it'll be done in 2006 sometime.   ;D
RayB
  • There's my post
    • RayB.com
« Reply #24 on: August 23, 2004, 11:18:30 am »
Sell it! Cuz if your cab will end up looking like MikMan's, it will look like crap. (No offense Mikman, but i really don't like the end result with that super tall coin door).
The always opinionated, Ray B.
NO MORE!!
pointdablame
« Reply #25 on: August 23, 2004, 12:14:51 pm »
Doh!
-Goz
Well I didn't wanna say it, but I think you and I have the same opinions here Goz :)
MiKman
  • Blah
« Reply #26 on: August 23, 2004, 12:19:08 pm »
Each to his own I guess.  I do like the over/under doors for functionality tho.
the3eyedblindman
« Reply #27 on: August 23, 2004, 03:31:06 pm »
I honestly dont care what any of you think of me or my posts, basically im here to get information so i can finish my cabinet. I dont know any of you, ive never seen any of you, so i dont care. So when Gozur or whatever ur name is puts smart comments in all my threads and thinks hes sharp saying things to a 15 year old, so be it. All i am looking for is information so i can finish. Hey Mikman, do you have a page or pictures of your whole cab, it looks real good. Ill probably do what you did to the coindoor, just squeeze it in, plus my cab is about a half inch to an inch off the ground cuz i have small wheels on the bottoms, so ill have alittle more to work with. All of you older guys that think my cab is gonna look like crap when its done, wait and see.......
I apologize to anyone who think i am being rude here, i just dont like when Gozur sais things about my posts.
MiKman
  • Blah
« Reply #28 on: August 23, 2004, 03:39:37 pm »
I don't think you are being rude, but I think that as a forum grows it's users, more and more rude people start to come out of the woodworks.  Not sure why people feel the need to throw no helpful, rude comments on this type of forum but whatever, doesn't bother me.  Just skip past them and look for the helpful stuff.  ;)
the3eyedblindman
« Reply #29 on: August 23, 2004, 04:42:12 pm »
Thats really what i hate about this forum, instead of people helping out, they just leave rude comments, or post threads about newbies and whatnot, if you arent going to help, just dont say anything. If someone wants to know what an ipac is for example, yeah, some of you may think thats a dumb question, but to someone who doesnt know, its a good question. So either answer or dont say anything, whats the point of the useless comments? Especially when i see i have a reply and get excited thinking someone has an answer and then i see the comments, really comeon now, whats the point? Anyways, I would like to see a pic of ur cab mikman, i sent u a pm, because i may have to do what you did on ur cab.
MiKman
  • Blah
« Reply #30 on: August 23, 2004, 04:55:24 pm »
check my projects announcements thread http://www.arcadecontrols.org/yabbse/index.php?board=10;action=display;threadid=10336;start=msg78010#msg78010
but here is a picture of the cabinet with my testing control panel in place... I am going to make some changes to it as it wasn't wat I had hoped for and I am surely glad I didn't cut my lexan and main cp with this layout :-)
MiKman
  • Blah
« Reply #31 on: August 23, 2004, 04:57:49 pm »
here is one more from an angle.
the3eyedblindman
« Reply #32 on: August 23, 2004, 04:58:19 pm »
looks real cool man, hope mine looks somethin like that, u can check out my marquee in the artowrk forum at the bottom of the thread labeleed "anyone willing to do marquee, very simple design, will pay $$$$$" check it out, leave a comment! ;)
Goz
  • KOTA
« Reply #33 on: August 23, 2004, 05:28:38 pm »
Not that I need to defend my replies to you as they have all started out with legitimate answers to your questions, there is an overall theme to your questions.
They are almost always posted to the wrong forum, they start out asking one question and end with you meaning to ask an entirely different question. I enjoy helping people, but some make that task more difficult.  On a number of posts, the answer has been only a google away.
What's that old proverb..... Give the man a fish and he eats for a day, teach them to fish... well you get it. Take a good hard look at your posts, and you'll likely get to see it from a different point of view. I believe this is the only post that I have not offered the correct answer to your initial question.
I'm starting to ramble and will stop with this said:
You ask for opinion, you will get opinion. You may not always like what the answer / opinion is.
-Goz
SNAAKE
  • Trade Count: (+29)
  • Last login:January 11, 2024, 12:21:50 pm
  • my joystick is bigger than your joystick !
« Reply #34 on: August 23, 2004, 05:35:49 pm »
Jeebus dont you people mesure anything at all ???
As far as I could remember,I drew the lines first,cut the hole for the coin door THEN put the bottom piece together.Then again I probely got away because I didnt use the UA2 plan(I am broke so I had to look at the pictures and build).I am kinda surprised at how you and MiKman made the exact same mistake.Interesting coinsidence... :-\
Here is mine with over under coin door.
« Last Edit: August 23, 2004, 05:44:48 pm by SNAAKE »
the3eyedblindman
« Reply #35 on: August 23, 2004, 05:37:54 pm »
yeah, u answer my questions, ill give u that, but you always throw in a rude or smart@ss comment somewhere in my threads also, and theres no point, if you have a problem with my posts or think their dumb, either answer or dont say anything, you dont gotta make me look dumb along with answering my questions, its just rude to someone who doesnt know as much as you.
SirPeale
« Reply #36 on: August 23, 2004, 05:44:48 pm »
Everyone needs to chill.  Now.  Or I'll get out my BOOM STICK.
the3eyedblindman
« Reply #37 on: August 23, 2004, 10:16:56 pm »
SNAAKE, its because the plans for that peice only measure 21 inches i believe, and the coindoor is about 20 and a half, so basically anyone else that makes a UA2 and doesnt look ahead of time will have the exact same problem as me and mikman.
IceCold
  • Last login:March 22, 2010, 05:11:22 pm
    • My MAME cabinet webpage
« Reply #38 on: August 24, 2004, 12:11:14 am »
Hehe, that's actually a picture I uploaded, it's a picture of how my coindoor looks with LED's.  You probably just tried uploading a picture with the same name.
big_garryb
  • Last login:June 09, 2006, 08:08:12 am
« Reply #39 on: August 24, 2004, 07:36:49 pm »
you should measure, draw on the wood, measure, double-check, measure, redraw if needed. measure and get someone else to measure.
i dont know how many times ive threw a tantrum through bad planning and not double checking measurements....... be sure, double sure, triple sure then CUT wood.
incidently, i also bought an over-under coindoor - but the bottom part is only 1/2 sized - it really does look the dogs bx: http://www.happcontrols.com/coindoors/40051400.htm
just my 2p worth
oh dear - not rain again......Scottish weather is crap, oh well - at least Mame can keep me company.
