Author Topic: Keypad for use in an MP3 jukebox?  (Read 5924 times)
filenabber
  • Last login:October 02, 2004, 11:11:48 pm
  • I brake 4 dots and ghosts
    • The Broken Joystick
« on: August 21, 2004, 09:50:03 pm »
I'm just starting to make an MP3 jukebox. I really like the control panel here:
http://www.cybertechdesign.net/mameroom//examples/P1010835.jpg
but i priced the buttons at Happ and they are $6 each -  there are 22 square buttons so that comes to $120 for buttons!!!!  I can probably cut the number of buttons down ( I want the triangle/arrow buttons), but I really would like to find an alternate source for a numeric keypad. Anyone found a suitable numeric keypad that could be used on a jukebox?
Can anyone tell me if this:
http://tinyurl.com/4fhe6 is referring to this:
http://tinyurl.com/4ndtj
I'm pretty sure it is but want to be sure
Brian
Zathras
  • Last login:June 06, 2011, 01:06:02 am
  • Yeah.
Re:Keypad for use in an MP3 jukebox?
« Reply #1 on: August 22, 2004, 12:22:09 am »
I used one of these 12 keypads from BG Micro - its non-matrixed and cheap:
http://www.bgmicro.com/prodinfo.asp?sid=097391203703703721618031121&prodid=SWT1068&page=1&cri=SWT1068&stype=3&time_out=19:57
If that doesn't work just  go to bgmicro.com and search on part: SWT1068
And fyi I've got info on everything I used on my Jukebox on a thread here.
Space Warped by Someone
Homebrew
  • Last login:May 03, 2012, 09:48:55 pm
« Reply #2 on: August 22, 2004, 12:13:48 pm »
If it interests you, i was able to use this keypad also from jameco:
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=121971
It is a matrix keypad, but i was able to decode the matrix and wire up each key individually.  It involved cutting some traces and soldering to each key, but its only a half-hour job or so using the info i posted here:
http://www.arcadecontrols.org/yabbse/index.php?board=5;action=display;threadid=14302
Just thought i'd offer yet another alternative.
filenabber
« Reply #3 on: August 22, 2004, 02:07:37 pm »
I'm using a hacked keyboard so a mtrixed one would work better for me (I think).
Brian
filenabber
« Reply #4 on: August 22, 2004, 02:11:35 pm »
It is a matrix keypad, but i was able to decode the matrix and wire up each key individually.  It involved cutting some traces and soldering to each key, but its only a half-hour job or so using the info I posted here:
That's the thread I linked to with the tinyurl links above :) Thanks! And thanks for the informative post. I'll probably be picking up two of them for the two jukes I'm working on.
I just got the cabinets yesterday - if anyone wants to see the cabs as they looked when they arrived (currently) take a peek here:
http://thebrokenjoystick.com/pictures/jukearrival
I'll be posting more pics and info as the projects progress. I'll probably start a thread on it once I've done some work on them.
brian
RacerX
  • Last login:April 25, 2024, 04:53:33 pm
  • Longtime member, sometime poster.
« Reply #5 on: August 26, 2004, 04:37:20 pm »
Brian
The triangle illuminated buttons are the only buttons that are $6.62 each.  All the others are between 77 cents and 87 cents.
I just bought enough of those buttons to make THREE jukeboxes about a month ago, and my TOTAL bill with shipping and all was only $112.34.
filenabber
« Reply #6 on: August 27, 2004, 08:23:58 am »
[quote author=RacerX
Can ypu point me to the specific URL or part number where you see square buttons for less than $1.00? Eevery one I have seen at Happ is ~$6 each. Maybe I'm just not looking in the right place. I'm looking for the white/red square buttons like the ones here:
Brian
RacerX
« Reply #7 on: August 27, 2004, 10:22:59 am »
http://www.happcontrols.com/pushbuttons/pushbuttons.htm
The ones used on that jukebox are the miniature momentary contact pushbuttons.
Here are the part numbers:
49-0578-11
49-3037-00
49-0578-00
« Last Edit: August 27, 2004, 11:44:46 am by RacerX »
filenabber
« Reply #8 on: August 28, 2004, 12:32:39 pm »
AHHHH!!!! I was looking at the illuminated ones! That's whyt the confusion! So...anyone know how you put the numbers on the buttons? Do they have caps you take off and put the numbers  under or are people just glueing numbers to the top of them?
brian
RacerX
« Reply #9 on: August 28, 2004, 02:53:23 pm »
brian
They are clear decals from a craft store.
unclet
« Reply #10 on: August 30, 2004, 01:06:33 pm »
Are the decals stuck to the top of the button or does the button have a cap which can be removed so the numbered decal can be placed inside the button top?
RacerX
« Reply #11 on: August 30, 2004, 02:51:39 pm »
They are stuck to the top of the button.  There is no cap on the buttons.
