Author Topic: haveing problems with ipac.  (Read 777 times)
sanousuke
  • Last login:March 13, 2009, 05:21:37 pm
« on: August 18, 2004, 03:26:08 pm »
I finally got my first testing control panel done. It works, the buttons, etc do everything.
It messes up though. Either my keyboard will stop working or the ipac will stop working, the buttons don't do anything.
Anyone know what can be causing this?
Goz
  • KOTA
  • Last login:September 03, 2020, 02:23:18 am
Re:haveing problems with ipac.
« Reply #1 on: August 18, 2004, 03:32:06 pm »
Could be as simple as a loose ps2 / usb cable. If you start up the ipac configuration utility when it fails, can you see the animated movements at all on the screen (you know push right and the joystick graphic moves right)
Could also try checking the jumper.
Have you contacted Ultimarc yet? Andy is awesome.
-Goz
sanousuke
« Reply #2 on: August 18, 2004, 03:38:32 pm »
I don't know what the ipac configuration utility is. I probably tryed installing it, but it gave me an error.
I know it's not a lose usb port. It works everytime I restart and after a little while, it just stops working, everytime.
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #3 on: August 18, 2004, 03:46:03 pm »
On this board we have had sooooo many people who have said "I know it's not ......." and it turned out to be just that.  I would suggest rechecking your USB connection.  Then check your wiring to the I-PAC.  Also go into the windows control panel and open up system and click the device manager tab to see if the I-PAC is still listed as being connected to the computer.  Also what program are you testing your control panel with?  Have you tried to see how it works in Notepad?
sanousuke
« Reply #4 on: August 18, 2004, 03:59:33 pm »
It lists it as unknown device with an x on it.
I am using usb port and I have the usb pin covered with the jumper.
I tested it with notepad and mame. I types letters in notepad and it punches/kicks in mame... When it works.
« Last Edit: August 18, 2004, 04:09:37 pm by sanousuke »
Goz
  • KOTA
« Reply #5 on: August 18, 2004, 04:35:09 pm »
USB pin covered or USB pins covered?
-Goz
Bgnome
  • Last login:January 10, 2005, 04:05:16 pm
  • Who's da gnome?
« Reply #6 on: August 18, 2004, 04:41:36 pm »
i think goz has a point there..  i dont think there is a usb jumper, especially on the newer boards.
"The board automatically detects which interface it is connected to (USB or PS/2)."
lots of useful info on the ultimarc website.  you might wanna check the LED error codes as well..
http://www.ultimarc.com/ipac2.html
sanousuke
« Reply #7 on: August 18, 2004, 05:33:13 pm »
It seems to be a problem with my 98
* sanousuke machine. I tryed it on my xp machine and it detected the device no prob. I haven't fully tested it yet though.
