Author Topic: Encoder Comparison Pages Back Online  (Read 7673 times)
Tiger-Heli
    • Tiger-Heli
« on: August 12, 2004, 02:26:06 pm »
Just wanted to let everyone know my encoder pages are back online at: http://www.mameworld.net/tigerheli/  They even got a home page to tie everything together.  I also included my comments on the Retroblast review of the KeyWiz.
(I know I need to update the pages to cover the I-PAC/VE, MiniPac, KeyWiz MAX 1.5, and maybe the new Two-Bit Score encoder on E-bay, and show the MK64 as discontinued, I'll get to it . . . )
Enjoy!!!
patrickl
  • Yo momma llama
    • PocketGalaga
Re:Encoder Comparison Pages Back Online
« Reply #1 on: August 12, 2004, 02:56:46 pm »
Heh, I see you still believe the performance of PS/2 is better  ::)
Really, someone should clock that sometime to get this out of the way. I'd put my money on USB (since the bandwith is vastly superior and a few interrrupts are not gonna kill that lead) On the other hand, who cares. With games running at 60Hz (max) the computer has ages to wait on your keypresses. Still, it would be nice to know.
Nice overview though. You sure take a lot of time to research all these things. very impressive work.
Bgnome
  • Last login:January 10, 2005, 04:05:16 pm
  • Who's da gnome?
« Reply #2 on: August 12, 2004, 05:23:33 pm »
i would be interested in seeing an updated review.
i just got the Two-bit encoder and soldered a ps/2 splitter for it last night.  i am now waiting on my joysticks/buttons so i can test it out on a temp cp..
if you need more info on it, i posted a fairly informative email about it in another thread and am willing to post whatever other info i have, (pictures, key map, etc.).
RandyT
  • Last login:Yesterday at 12:12:44 pm
    • GroovyGameGear.com
« Reply #3 on: August 12, 2004, 11:35:33 pm »
And I see you still haven't done any research to support your rolly eyed posts. ;)
Yes, someone should.  But there is more at play than raw bandwidth when comparing these things.  1.5mbs is a theoretical maximum of a "low-speed USB device".  How close any device, especially a keyboard device, comes to this speed depends greatly on the capabilities of the microprocessor used in the device, the efficiency of the code inside and the software support of the host system.  Try using USB with the rudimentary support included in the BIOS of most motherboards if you don't believe this to be true.  It might work, but you wouldn't want to use it for anything.  On the other hand, the BIOS support for PS/2 works very well.
This reminds me of the Commodore 64 days and the push to attach high-speed modems to it.  In theory, you can use every available processor cycle to pump a data byte out of the port at 9600bps.  The problem was (and maybe still is, I haven't looked at the 64 scene for while;)) that even though technically the 64 was speaking at 9600 baud, it could only assemble the data prior to transmission at a rate similar to that of a 2400 or 4800 baud modem.
In other words, bandwidth does not necessarily equal throughput.  And this is just one of a number of possible variables that can affect performance.
You might also wish to ask the question why, when given the choice of using either interface on an encoder that supports both, PS/2 is usually the one used.  There must be a reason, no?
Absolutely. the dedication to those pages impresses me every time I look at them.  Nice job TH!
RandyT
*edit*
spelling....
« Last Edit: August 13, 2004, 12:18:17 am by RandyT »
RandyT
« Reply #4 on: August 13, 2004, 05:34:54 pm »
Ha, ha, Randy. You always know to find some out of the way example ("a very crappy USB device might be slower than a non crappy PS/2 device" or "many many years ago there was a computer whith a really slow CPU that was unable to completely use up all the bandwidth") to "prove" your point. Again I wonder why you claim I didn't research the issue. Of course if you attach a crappy USB encoder it will not work, but the i-PAC is a fine encoder and it does work. What 's the point of such statements?
The point is, it was a real world parallel of the difference between the "marketing hype" and what is actually the case in a lot of instances with USB devices.  I'm sorry it was lost on you, I'll try harder next time.
And for the record, you just attempted to turn this into "yet another KeyWiz VS IPAC" debate, which I am not going to get into again.  The statements I am responding to regard your general "USB is always better" rhetoric, nothing more.
If you want some point actually relating to the discussion at hand then think about this; 1.5Mbps is the theoretical maximum bandwidth for USB. For PS/2 it's something like 10kbps. I'm pretty sure that factor 150 will matter much more in delays than any potential interrupt conflicts.
And this is what shows your lack of research or real understanding of the topic at hand.  Your statement is along the same lines as this one:
"A car travels at 400 miles per hour, therefore a car is faster than a plane."
While this isn't necessarily a false statement, it is pretty far from being accurate.  Yes, a car has traveled at 400 miles per hour.  Does your car?  Does mine?  Does any production model?  Can it turn a corner?  Can it maintain that speed long enough to be useful?  Which plane?
Your statements use theoretical maximums as though they were the norm, and therefore are misleading and not entirely factual.
Actually PS/2 is so slow that it cannot even be used in some applications (for instance high res tablets). PS/2 doesn't offer enough bandwidth for the necessary information stream.
And you wouldn't want to use it for transferring data from an external Hard-drive either, but what bearing does that have on the point?  Until well after USB was introduced, artists tablets produced by WACOM and others used normal RS-232 serial.  Not much of a speed demand there I guess, as these functioned easily at 9600 baud (slower than the PS/2 bus.)
A byte of data sent over the PS/2 keyboard port is framed at 11-bits.  The max quoted frequency of the clock is around 16.5khz, or 16500 bits per second.  Drop that back some to 15000 bits per second for compatibility purposes, divide it by 11 and you have roughly 1363 bytes of data per second.  Normal keys on a keyboard generate 3 bytes of data, 1 at depress and 2 at release.  So even if it were possible to press and release 454 buttons within the time frame of 1 second, the PS/2 bus should still be able to handle the traffic.
I'm not so sure 4 players pounding many buttons and wielding 4 joysticks wouldn't give much more problems on a PS/2 encoder than the possibility of say a printer needing an occasional USB interrupt delaying your USB encoder. I'm pretty sure bandwidth issues give a much bigger delay problem than any possible USB interrupts blocking the USB encoder might.
If you aren't sure, why make statements like these?  I can tell you that I am sure that there would be no issues with PS/2 in this instance, at least not caused by a limitation in the interface.
If you would like to conduct a test, wire your encoder up so that a single button activates all inputs and use a program like Ghostkey to monitor the results while clicking the button a few times in rapid succession.  Hold the last press and record what you see on the screen.
Do this with both USB and PS/2 and then tell me which one you think will have the greatest possibility of a problem in the scenario you presented.  I await your results.
For more normal use I wonder if any performance benefit (be it for PS/2 or USB) will actually matter? Will you even notice a couple of ms delay?
Some people notice the absence of certain frequencies in their music, even though most can't hear them to start with.  Some are annoyed by 60hz flicker in fluorescent lighting although millions don't even notice.  You tell me.  But one thing is certain, if it doesn't feel right to you, it probably isn't.  Before I designed the KeyWiz, I was using a PS/2 keyboard hack.  I used to think it worked pretty well, until I made the switch.  Turns out that the keyboard had an inferior processor and I didn't know the difference until I actually had a frame of reference.
So yes, a few ms of delay can be noticed if present.
I guess it's habit and it's cheaper (initially). For me it was mostly caused by people spreading misinformation. When I bought my i-PAC the 6 button myth was still alive. In the meantime Andy Warner explained the 6 button restriction is nonsense and that speed wise there is no difference. That is much more important to me than people quoting reference manuals. Andy really does know how it works since he build the thing.
What goes on between you and your mentor is not for me to comment on.  However, "habit" as a reason to use PS/2 over USB is just plain silly :)  There actually are valid reasons and that isn't one of them.
...I don't want to rewire my controller when I switch to a new computer and so I don't want to depend on PS/2 alone. In fact my current PC has no PS/2 port.
I'm sorry your salesman was able to convince you that less options was actually a "feature" on the system you bought.  Better luck next time.  Meanwhile, 90%+ of current systems still have the full complement of ports.
- It's much easier to connect control panels to the PC. You put the hole stuff in the CP box and one wire comes out. For instance, rotating panels aren't gonna happen without USB.
More misinformation.  Ever hear of switching connections at the input side of the encoder rather than the output side?
[rhetoric about "everyone is changing to USB" snipped...they said it would have happened already, they tried, it still hasn't and isn't going to soon.  We did this one before}
Are all gamers who use USB joysticks, steering wheels, trackballs, game pads and such suffering from poor gameplay? In fact, how many people insisting on PS/2 for their keyboard encoders have a USB trackball or USB spinner in their CP?
Well, the true arcade trackballs from Betson use PS/2, as well as the one on my cabinet.  I engineered replacement encoder wheels for the Betsons with 4x the resolution and it doesn't skip a beat.  USB gamepads, steering wheels and joysticks don't pretend to be keyboards, so not an apt comparison.  But I'm sure they work fine.  Better? Not necessarily.
The only reason to go for PS/2 is if you use an older computer or older OS and USB doesn't work really well in it yet (or maybe even not at all). In all other situations USB just makes much more sense when you think about it (especially in the long run). I guess it just hasn't gotten through to people yet.
I guess it's a good thing we have you here to get it through our thick skulls. Sheesh! :)
It's not that big of a deal so why bother thinking about it? Well, at first I didn't think things through either so I went for PS/2, but in the end I got bitten and after I researched things I now understand that USB is the better option. I'm really happy my encoder was ready for USB.
Err.. how were you "bitten" again?  Anyway, you have your opinion, I have mine and everyone else has theirs.  I'm glad you are as happy with USB as the thousands of others are with PS/2.  Isn't that what it's really all about in the end?
RandyT
*edit*
spelling.......
« Last Edit: August 13, 2004, 07:26:06 pm by RandyT »
Bgnome
  • Who's da gnome?
« Reply #5 on: August 13, 2004, 05:44:23 pm »
for me, i dont feel like i will ever approach the point where bandwith will cause noticeable differences.  it is all a matter of convenience.  i have a ps/2 port so i will be using it.  i also have a limited number of usb ports.  i could use a hub but i choose not to.  i like the option of choosing ps/2 or usb depending upon availability.  i hope the reviews do not delve too much into the quality of such connections since that, to me at least, is nowhere near as important as quality of functionality..
PixelCloud
  • Last login:April 26, 2005, 07:15:14 pm
« Reply #6 on: August 13, 2004, 06:16:15 pm »
"I'm sorry your salesman was able to convince you that less options was actually a "feature" on the system you bought.  Better luck next time.  Meanwhile, 90%+ of current ystems still have the full complement of ports."
only one thing i woudl like to comment on here...
there is no need for legacy ports anymore. I mean if you need legacy ports you probably have a computer that supports them anyways ;). But if you are buying a new one there is really no point, (USB keyboards are cheap)
Bgnome
  • Who's da gnome?
« Reply #7 on: August 13, 2004, 07:04:07 pm »
to paraphrase what paigeoliver said in another thread: buying computers for mame is stupid.
i think that there are still a whole lotta people, myself included, bringing life back to old, outdated systems.  dont leave us out of the loop..
RandyT
« Reply #8 on: August 13, 2004, 07:44:23 pm »
Randy,
I'm not trying to prove USB is better for gaming (although I do feel having USB at least as an option is a must in an encoder which is supposed to last at least a decade). However, I am out to refute the vague claims that PS/2 is the only way to go. Unless there is some actual proof to the contrary, Andy Warners explanation that there is no discernable difference is valid (at least in the case of the I-PAC).
I won't argue with someone vicariously through another.  I only want you to think about the scenario you gave me and conduct the test as I outlined it.  You can then give me your own conclusions.  I have no interest in what you were told or by whom.
For me the demise of PS/2 was the deciding factor, for others it's a rotating control panel needing a single cable to connect all controllers, again others don't have enough connectors of a certain type and then there are some who worry about vague claims that there might be a problem. I just hope the latter category understands that that's just pure nonsense so they can base their choice on more important matters.
Err...before you call them nonsense again, do the test I mentioned.  Be sure to look through the posts of all the individuals experiencing problems with connecting their encoders via USB and pay careful attention to the solution provided to them by other readers (I'll save you the trouble, they are told to use the PS/2 port.) Sorry Patrick, but there is nothing vague there.  This is not to say that it happens to all or even a majority, but the issues are real and seen all the time.
RandyT
(P.S. do the test ;) )
RandyT
« Reply #9 on: August 13, 2004, 09:25:34 pm »
I'm not interested in pressing more than 14 or 22 buttons
If you think its anywhere near 22, then you really need to do the test.  Why not just check it out and report what you see?  It's not that hard to do, and will put this to bed once and for all?
If I do it and post the results, you'll just call me a liar.  Why the aversion?
RandyT
RandyT
« Reply #10 on: August 13, 2004, 11:44:39 pm »
If this were true, the legacy ports would already be history.  Evidently, the MB manufacturers see it otherwise ;).
But seriously, this has been discussed in the past on here and a search will bring up more than you probably want to hear on the topic.
RandyT
Tiger-Heli
    • Tiger-Heli
« Reply #11 on: August 14, 2004, 08:53:04 am »
Man, oh man, I leave my computer for a day and look what happens . . .  :P
Okay, this has been discussed before, and I don't want to belabor the point or fan the flame war. . .
PatrickL:  I found it interesting that in the post I am replying to you said "Really, someone should clock that sometime to get this out of the way."  Then when RandyT asks you to test it you post "Maybe if you tell me what would it prove I would be interested. Right now I just don't see the point. I wasted enough time on this already."
Obviously it's important to you or you wouldn't harp on it so much.
For the record, to me, it's not that much about speed or performance as capability.
1)  There IS a limitation to the I-PAC in USB mode.  It's more like 14 or 16 keys instead of six, but it's there.  You can make the argument that this is similar to the Japanese speedbikes being limited to 185 Mph - it doesn't make a difference in most circumstances, but it's there.
2)  I personnally experienced slowdowns with a pair of cheapo PC USB trackballs in MAME.  These were sharing a hub and I haven't seen issues with my keyboard with a USB connection as opposed to a PS/2 connection.
3)  I fully expect that 90% (probably more) of MAME users could use either USB or PS/2 mode with no noticeable difference in performance.  That said, if you search the threads on here, you will find dozens of posts of users having trouble with USB mode with their encoder.  Since almost all USB encoders (I-PAC/2, I-PAC/4) also supported PS/2, it was simple enough for most people to switch to PS/2 mode if they couldn't solve the problems.  However, I can only remember maybe one example of a person having a problem with an I-PAC in PS/2 mode that was fixed by using it in USB.
4)  I would like to see a speed/performance comparison between USB and PS/2 also, just to put it to bed, but you also need the following conditions -
Should use the same encoder for both tests, same keys and same programs, and should test multiple simultaneous keypresses.
Also, the tests should be done under both Win98SE and WinXP, and for that matter, on entry, mid-level, and high-end systems to get accurate benchmarks.
Tiger-Heli
    • Tiger-Heli
« Reply #12 on: August 14, 2004, 09:00:09 am »
Yep, I'd like the info.  Also, I was curious whether the grounds are common on it (There are two grounds on each of the eight 10-pin Molex connectors).  Are the grounds on Connector 1 common with the grounds on Connector 8?
Having said the above, I would prefer to concentrate the updates more on the minipac, I-PAC VE, and KeyWiz Max 1.5, as the two-bit encoder is about 40 units, NOS from the early 80's and only available on E-bay for probably the next six months, while the others are current production models.
Hoagie_one
  • Um....whats a cabinet
« Reply #13 on: August 14, 2004, 09:00:10 am »
anyone have any experience with that Two-Bit Score encoder?  That sounds like the ultimate multiplayer encoder if it works well.
Tiger-Heli
    • Tiger-Heli
« Reply #14 on: August 14, 2004, 09:13:28 am »
That's what we were talking about (besides USB vs. PS/2).  Bgnome has one.  Non-programability is a big drawback if you want to use it for more than MAME.  The price is right, though . . .
Bgnome
  • Who's da gnome?
« Reply #15 on: August 14, 2004, 09:44:09 am »
i posted the keymap here:
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=22871;start=msg188768#msg188768
original email about how it works:
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=22851;start=msg186817#msg186817
pins 1 and 10 are common ground and connected to eachother on each bank, so you really only need to hook up 1 ground wire.  my best guess is that there are still over 60 left, but it is in short supply.  also, judging by the keymap, A, E, F, and G are repeated so that in essence only gives you 60 independent inputs.  i havent gotten my buttons in yet so i havent been able to do any thorough testing but i did manage to get at least 36 keys pressed using strips of aluminum foil and my fingers.  at the moment, i am soldering wires to it and will be mounting it into a plastic vhs box from blockbuster, (barely fits),  along with barrier strips.
one thing i will note, but i dont know if it is just my setup.  i am using it with a laptop which has only 1 usb input and 1 ps/2 input.  i soldered  a ps/2 splitter together according to a schematic i found online which lets me use a mouse and kb at the same time.  i have a usb kb plugged in the usb slot.  my splitter works but my encoder board seems to stop working sometimes.  i have been testing the board by pressing the f1 button that is directly on it.  i am fairly certain the soldering job is ok.  but my trackball unit does have 3 superbright red leds in it so im wondering if its just an issue of limited power supply..
« Last Edit: August 14, 2004, 10:08:44 am by Bgnome »
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #16 on: August 14, 2004, 10:08:38 am »
I care about the performance USB vs PS/2 (in the sense of timing). I have no idea what Randy's test would prove and he won't explain either. I don't feel like taking my CP apart just to do some useless test.
In fact I feel rather ashamed I responded to his weird posts. I can't say I saw a on-topic argument in any of them. I'll just remove my replies, do the silly test and summarize the whole thing. Sorry for cluttering up your thread. I do realy like your site, but I also think you should rethink the USB vs PS/2 issue (even if it really is a non issue).
BTW I'm not arguing compatibility issues or specific scenario's where either USB or PS/ are preferred. I'm saying USB vs PS/2 performance is either a non-issue and maybe even it has a winner for USB.
« Last Edit: August 14, 2004, 04:17:11 pm by patrickl »
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #17 on: August 14, 2004, 03:11:17 pm »
OK, sorry for the delay, but I just can't seem to find my USB cable. The workshop has been cleaned up by the missus and now I can't find the cable.
I'll just recap my (deleted) posts:
Comparing PS/2 vs USB; performance issues:
- USB will suffer in response time because it's lower in priority, needs more handling in BIOS and OS and it shares the bus with other devices. Only other interrupts can effect bus delays though, so USB harddisks and printers etc (if people would even have those connected to their cab) are of no influence. I'm hard pressed to see the whole extra overhead caused by these issues lasting longer than 1ms. For instance the max interrupt can be 40 bytes on a 1.5Mbps connection (i.e. something like a .3ms delay)
- According to PS/2 protocol, each key press takes 1.1ms to be transmitted and a key release takes 2.2ms (PS/2 rated by design at 10kbps and 11bit's used per byte transmitted) At a frame rate of 60Hz there are 17ms per frame. Now imagine 4 players moving sticks and pressing buttons franticly. So with PS/2 you could release at max 8 keys within a frame before you actually start suffering more than a whole frame delay due to transmission speeds. Even with fewer keys pressed (for instance during one player games) it's easy to see these delays will have a similar (if not worse) impact on response times compared to the USB delays mentioned above.
- A large number of keys pressed/released is not so much a cause for delay with a USB encoder since the transmission is so much faster.
- The fixed limitation on the maximum number of 6 keys pressed simultaneously only exists in standard keyboard encoders. An encoder like the I-PAC (in USB mode) will have a limit on something like 14 to 22 keys simultaneously.
There are a few situations where circumstances basically force you to use either PS/2 or USB:
- If you have a pre USB computer or use an OS without (mature) USB support you go for PS/2
- If for instance you use a Mac, you are building a rotating control panel (where you will need to have only one "flexible" wire coming from the CP) or you have one of the newer PC's without PS/2 ports then you go for USB
I might add some considerations:
- For 4 player fighter cabs, performance issues with PS/2 might be a consideration, USB functions better here.
- If you think you are goinf to be in situations where something like 14 to 22 keys are pressed simultaneously, an USB I-PAC will not work. Although if you are in that situation PS/2 will suffer severly from performance issues too. You would actually need to find a completely different alternative or live with of the problems in either USb or PS/2.
- Futureproofing; If you keep in mind the time frame you will be using your cab for then it's wise to consider that USB seems to be pushing out PS/2 slowly but surely. Legacy free PC's have been coming out already and so you might end up with one as a replacement in the future. Maybe not tomorrow but what about in 5 or 10 years when your current PC breaks down? Remember how quickly the old big AT keyboard connectors went out the door after the new ATX motherboards were introduced.
So basically if there is no pressing reason to force you on either PS/2 or USB, it simply doesn't matter which you choose. Both will work fine and other factors should decide which encoder to pick. In hindsight I'm very glad my controller has both PS/2 and USB.
monkeybomb
  • PM me to find out how to get a custom title like mine!
  • Last login:January 03, 2018, 07:16:29 pm
« Reply #18 on: August 14, 2004, 04:37:02 pm »
Let me start by saying I do not understand the deep technical side of any of this.  So, I don't quite get why this is so heated.
I am a keyboard encoder customer and user.  I play fighting games and sometimes I press 2 directions, three buttons and a friend could be doing the same.  that's 10 buttons at a time.  I use a ps/2 connection (keywiz) and have NEVER had ANY issues with it.  Why would I use a up a USB port that I could use for something else, only to leave a ps/2 port unused.  I also see a ps/2 connection on every MOBO at Fry's.  So what is all that talk about?
I do NOT want to contribute to flames, I'm just interested in why this debate exists.  And does the debate move beyond the technical realm?  Does it have true practical common usage value?
Thanks for reading
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #19 on: August 14, 2004, 04:48:53 pm »
That's just the point I'm trying to make. You normally won't even notice the difference between USB and PS/2. What I object to is claims that USB cannot be used (especially since there is no real proof to back them).
Tiger-Heli
    • Tiger-Heli
« Reply #20 on: August 14, 2004, 04:58:06 pm »
[quote author=patrickl link=board=1;threadid=23148;start=0#msg189573 That's just the point I'm trying to make. You normally won't even notice the difference between USB and PS/2. What I object to is claims that USB cannot be used (especially since there is no real proof to back them).
Who ever claimed that USB could not be used (unless you have one of the non-ultimarc encoders that does not support it.).
The point of my comparison was that many of the ultimarc encoders support either USB or PS/2, so the question came up as to which is better.
And I still stand by my basic premise that USB is more convenient for hot-swappability for a desktop controller, but PS/2 gives less complications for anything else.  And speed is really a secondary concern in my opinion, although if I see glitches in the gaming software, that is a concern.
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #21 on: August 14, 2004, 05:20:53 pm »
Randy does (or at least he keeps summing up reasons why PS/2 is virtually always the way to go).
I actually agree with your points. It's just that I think you put a bit too much emphasis on USB performance issues where PS/2 could have similar problems. In effect you even mention that, but the underlying tone I got was still that PS/2 is generally faster than USB. I'd say it varies which is faster. That's why I basically only replied with a smiley.  It's probably like IDE and SCSI. Both are faster in certain situations. I guess I'm a sucker for senseless debates.
BTW I didn't understand why you thought hotswapping was important (I thought you were talking about swappable panels), but for desktop panels then yeah USB will probably work better too. I actually had some PS/2 problems when I was hotswapping my standalone panel with (PS/2 cable). A couple of times I had to reset my computer to get the keyboard working again.
Tiger-Heli
    • Tiger-Heli
« Reply #22 on: August 14, 2004, 05:56:52 pm »
And you keep saying that USB has a performance advantage with NOTHING to back that up, besides the raw absolute bandwidth numbers.
I don't know the real answers, but it's not like you're posting "My I-PAC sucked in PS/2 mode, and I connected it to the USB port and it really flies now."
Again, I didn't really mean to imply that PS/2 was faster than USB - it might be, but that wasn't the intent.  I did mean to imply that for most users, PS/2 will give less problems and better overall performance than USB, not that USB is always a poor choice or that it won't work fine for most users.  If my pages imply a speed rather than an overall performance issue between the two, I may need to revisit that.
Agreed - and it may well come down to whether you are using USB trackballs and spinners along with the encoder or not (again, not saying that you can't do this, or that it's a terrible idea, but it wouldn't surprise me if it had an effect.)
Yep, I have a home PC that I'm adding desktop controllers too.  A little different situation than a MAME cab.  OTOH, about every 10th re-boot on that PC (Win98SE), I have to unplug the USB mouse and plug it back in so Windows can find it again, so who knows . . .
RandyT
« Reply #23 on: August 14, 2004, 06:27:48 pm »
I think you mean "re-write history".  See the quotes in my posts for what was deleted (I knew there was a reason I do that all the time.)
Don't forget to mention the limited number of endpoints on the USB controller, which account for the simultaneous keypress limitation, and then there's the whole processor needing to take time to assemble and possibly pad the packets and the need to send more data down the bus than PS/2 to do the same job.
Nice regurgitation, but this is so far out of the realm of your expertise (based on every other post by you,) one has to wonder if you've aquired a "puppet master", not that they appear to know more about this than you already do.
In any case, just about everything you wrote is based on bad information or is just outright rubbish.  Your 10kz number is flawed.  This might be the case with the slowest of the slow PS/2 controller chips, but not in the last 5-7 years.  The average is roughly (by my own estimates and experience) 50% faster than what you are stating.  If it wasn't, the KeyWiz wouldn't work.  I can't comment on other encoders though.
And the rest of the info is bogus as well.  Ever hear of a keyboard buffer?  With PS/2, the BIOS is responsible for receiving data from the keyboard (encoder) and stuffing the keyboard buffer on the host system.  This happens almost in real-time, as long as the Host isn't holding off the keyboard (encoder) from sending more data (which happens very rarely, unless there is a severe problem with the system or a nasty piece of software, which would cause problems for any interface.)  This ensures that the keyboard buffer is always ready to supply data the moment the application is ready for it.  At that time, there are no speed limitations because the code retrieves data from the buffer at the speed the host system/OS allows.  How much data it retrieves at any given time will depend on the way the currently running software is written.
Just because the game doesn't look for keys but every 17ms doesn't mean that the PS/2 encoder is sitting there "dumb" waiting for it to be called on.  It happily (and constantly) chucks data out unitil the host buffer is full and then it continues to load it's own buffers until it becomes full.  Again, unless there is some severe problem, it would be an extreme rarity for it to ever come to that.
If you look at what I just typed, you would see just how little a role the speed between the encoder and the PC plays.  What does play a role, is the ability of the encoder's processor to handle the extra "packetizing" steps required  by the USB protocol and the PC to process the data to decide what it's for and where to put it, both of which aren't required by PS/2.
I see this "fuzzy" number tossed around, but never actually hear a good explanation, so I'm going to take a guess based on what I know.
The processor in question has 3 endpoints, 1 of which is reserved for modifier/system keys like LSHIFT, RSHIFT, RALT, LALT, RCTRL, LCTRL, and the Windows keys.
The other 2 endpoints are set up to carry 7 keys each.  A normal USB keyboard would only use 1 endpoint for key data and one for a modifier which would allow for 6 or 7 pieces of key data and up to 8 modifier keys.  But a normal USB keyboard uses a matrix, so it blocks and keeps you from pressing all those at once.
So, with a USB encoder based on that same CPU, I would think that if you were pressing all non-modifiers, you would get only 14 simultaneous keystrokes.  But if modifiers were pressed at the same time, you could get up to 22.  This would mean you would be forced to use the modifier keys in your button map if you were looking for that maximum 22 number.
Am I getting warm? ;)  (check with your source if you don't know)
*cough* sorry, I just choked on my coffee.  I actually agree with this statement  :D
Well, mostly.  They do make multi-conductor cables and connectors with enough lines for 33 connections, not that most (or any) panels would use that many in a rotating situation.  And yes, the cable is plenty "flexible", just not as thin :)
Whoops!  There you go again.  More rubbish and uninformed opinion being delivered as fact.  How about a detailed explanation to back this up?  Surely you have one or you wouldn't make such statements, would you?
Oh, and be sure to ask what protocol that second chip is using to speak to the other one on those 4-player USB encoders.  It wouldn't be PS/2, would it?  :)
- If you think you are going to be in situations where something like 14 to 22 keys are pressed simultaneously, an USB I-PAC will not work. Although if you are in that situation PS/2 will suffer severly from performance issues too. You would actually need to find a completely different alternative or live with of the problems in either USb or PS/2.
This is just getting comical now.  Your conclusion about PS/2 struggling is based on the faulty conclusion you made above.  The PS/2 encoder will happily deal with as many keypresses as you need to use and will not suffer anywhere near the problems you say are on par with blocked or missed keys on the USB counterpart.  You should really stop now.  No, really :)
Ummm...I still use one of those systems with a big ol' AT to PS/2 keyboard adapter as part of my development system  :D
Anyway, at the risk of sounding flippant (like I haven't already)  if you can't find a system with a PS/2 port capable of doing what you want 5-10 years down the road, or afford another $35 bucks for the next latest and greatest (it won't be what you see on the market today, that's for sure), then you really need to find a different hobby.  It's either too expensive or too complex for you.
If I'm able to stand in front of an arcade machine without a walker in 10 years, I'll be happy  :D
Again, a true statement, but for some there are reasons, and they do press...hard.  The two are not created equal in all respects so it is important to use the one that will cause the least amount of grief, whatever the grief is defined as for that individual.
And again, I'm happy you are happy :).
RandyT
*edit*
formatting......
« Last Edit: August 14, 2004, 06:32:13 pm by RandyT »
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #24 on: August 14, 2004, 06:37:46 pm »
I post those figures since they explain quite clearly why there is a potential problem with PS/2 as well as with USB when large numbers of keys are pressed. If you claim you will have over 22 keys depressed at the same time you'll run into trouble with PS/2 too. Randy claims PS/2 is 1.5 times faster than I do, but still. Release 22 keys and you'll still be waiting at least 32ms for that to work it's way over the cable (not even considering the overhead)
I don't have the numbers either and since noone seems to believe Andy's answer there apparently is noone who has an answer. The indications say to me that both have their issues in certain (very unlikely) exceptions and both will work fine in general situations.
You are right that I wouldn't say that my I-PAC was "flying" on USB. I'd say that it was exactly the same (with USB) as before (with PS/2).
Again, nothing to get worked up about. I agree with you on the big picture.
« Last Edit: August 14, 2004, 07:06:37 pm by patrickl »
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #25 on: August 14, 2004, 06:45:49 pm »
Again you completely misinterpret my post (buffers have nothing to do with transmission times and I don't say keystrokes are lost, but that they arrive late), then you make fun of your own idiotic interpretation and to top it all off you try to sidetrack the discussion with subjects that have nothing to do with the discussion at hand.
Tiger-Heli
    • Tiger-Heli
« Reply #26 on: August 14, 2004, 06:46:51 pm »
Forgot to mention, actually on my PC I use an AT keyboard, into a PS/2 adapter, into a USB converter . . .
RandyT
« Reply #27 on: August 14, 2004, 11:18:25 pm »
Well that was one part of the two+ pager I just wrote.  How about the rest?  Everything I wrote has something to do with this topic.
I did misunderstand the point of that statement, but what I said is still true and the buffer is still important there.  Let's look again just for fun.
The software is responsible for retrieving the keyboard data from the buffer.  It might do it every 17ms, as you stated, or every 35ms or ? ? ?.  It's up to the software and has nothing to do with the interface.
But let's use your 17ms as though it were somehow set in stone (keeping in mind that it is certainly not).  But before I go on, and for the sake of others who might not have a feel for the time frame of 17ms, do the following:
Speak the words "one mississippi".  Did you do it?  Ok, in the time it took you to do that, 17ms went by 60 times and was far less time than it took you to make the "wuh" sound in "one".  Now let's continue...
Based on the maximum speed specifications of the PS/2 port, which is in reality about 1/2 millisecond per 11-bit frame, it would be possible to send 34 button presses or 17 releases or a combination of the two with the appropriate number differences.
Now, in order for any button "event" to be delayed by an entire "frame", umm... 17/1000ths of a second, it would need to occur at the precise instant the software was finished emptying the buffer and went on to the rest of it's business.  If it occured 6ms afterward, it would be delayed by only 11/1000ths of a second, 12ms afterward it would be delayed by 5/1000ths of a second and so on.  In order to be more than 1 frame late, you would need to have, on average, more than 24 button transitions that occur in 17/1000ths of a second.  If you tried with every bit of determination you could muster, you, as an individual, would have virtually no chance of making 5 transitions occur in that amount of time, let alone 25.
4 players could be hitting or releasing 2 buttons each with all of them hitting or releasing diagonals (not just holding a direction), in a window of 17/1000ths of a second, and delivery of the data via PS/2 still would not exceed a 17ms frame.  Again, exceeding the maximums merely by chance, even with 4 players banging like mad, is a virtual  impossibility.
There have been encoders on the market (long fixed by now and certainly not mine!) that had problems with games requiring only 3 presses within a "frame".  This was due to poor firmware, questionable hardware design or both.  But as I said, the culprit has been fixed as far as I know.
The question is, what makes you think that the extra data and processing steps required by USB aren't going to give you similar or possibly worse performance?
But here's something that I found interesting during my research, and someone please correct me if I'm wrong, but I'm pretty sure it was from the HID white paper or something of similar reliability (MS?)
The USB keyboard data is delivered to the host in packet form, meaning that is a collection of bytes with header and data information.  The packet is sent serially (one bit after another) and then "re-assembled" into a packet again at the host.  The host then identifies the packet as being one from a keyboard, pulls out the keystroke data and puts it into a virtualized keyboard buffer.  But here's the interesting part...as the host deals with the data as a "packet" there is no particular order in which it is placed into the virtualized buffer.
This would mean, if I'm not mistaken here, that if you and your competitor were in a situation where the first one to press the button were to win, and you both pressed close enough together that your keystrokes ended up in the same packet, the winner is pretty much picked at random :)
So it's quite possible that the FIFO system of PS/2 is superior in this regard.
Until you examine the full workings of a device, meaning all internal protocols used in communication with other components and the methods used in the microcode, you won't ever get a clear picture as to the real performance capabilities the device can offer.  Regardless of whether the final output is USB or PS/2.  Remember, the output of anything can only be as fast as the slowest part coming in or the slowest part of the process as a whole.
RandyT
« Last Edit: August 15, 2004, 12:46:20 am by RandyT »
krick
  • Last login:February 08, 2023, 08:30:27 pm
  • Gotta have blue hair.
« Reply #28 on: August 15, 2004, 03:38:00 am »
This is precisely why I think there really needs to be a PCI version of the ArcadeVGA card.
Andy, are you listening?
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
Bgnome
  • Who's da gnome?
« Reply #29 on: August 15, 2004, 11:54:31 am »
this talk of bandwith has got me worried..
if i have a splitter on my ps/2 port for my trackball and encoder, will i suffer performance issues?  keeping in mind that i intend on using it in a 4-player situation and that the data/clock lines are all separate..
RandyT
« Reply #30 on: August 15, 2004, 12:50:04 pm »
If you are talking about a laptop style splitter where there actually are separate lines for clock and data and the "splitter" just routes the wires to the right places, then no, it's the same as separate connections.
I would say that this is your case, as the trackball and keyboard encoder use completely separate interfaces and couldn't share one even if they wanted to.
So stop worrying ;)
RandyT
Bgnome
  • Who's da gnome?
« Reply #31 on: August 15, 2004, 01:16:34 pm »
thanks for clearing that up randy!
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #32 on: August 15, 2004, 02:32:33 pm »
Would you even use that trackball in a 4 player situation?
BTW that's something to keep in mind with USB. If you connect several USB devices to the same USB host controller (and they are used simultaneously) they might interfere. Again something that's hard to quantify, but it would make sense to use different USB host controllers for each device if you can (most computers have the USB slots in pairs connected to the same USB host controller)
Bgnome
  • Who's da gnome?
« Reply #33 on: August 15, 2004, 02:51:59 pm »
i most likely wont be using the trackball while 3 other people are banging away at the controls but it could be a concern.  i finally got this two bit encoder soldered and wired up and redid my splitter and everything seems to be working so far.. cant wait till i get my buttons and sticks in..
Bgnome
  • Who's da gnome?
« Reply #34 on: August 18, 2004, 04:47:35 pm »
the creator has elaborated on some information in his ebay listing:
Additional Information. Since I have listed this item I have received hundreds of E-mails asking some common questions. Here are the answers to some of these questions in paraphrase format:
Does this encoder use a matrix, and how does it send key data to the PC?
This device encodes each input as a single keystroke. When the input pin goes LOW (pulled to GROUND) the encoder will send the corresponding keycode ONCE, then remain inactive until the input pin goes HIGH (open). At that time, the encoder will send the BREAK CODE to the PC. The encoder is NOT typematic. The encoder operates on the SINGLE IDENTITY principle where each input sends only the make code once. The encoder does NOT use a matrix, nor is it built around a matrixed chip that has been "dematrixed" by external circuitry. This encoder will not ghost, block or drop keystrokes. Since it is not a matrix, the problem with matrix key "duplication" does not exist. This encoder was designed originally to be used on very expensive, very high end gambling machines used in Las Vegas, Atlantic City, Monte Carlo and other famous places where gaming machines are played. Therefore, since the board would be used in gambling and would be responsible for handling REAL money, special precautions were written into the code to protect the single identity operations and to be absolutely sure no keystrokes would drop.
Will this encoder overrun the PC's keyboard buffer and cause lost control of the buttons?
Since this encoder only sends the keystroke once (non-typematic) it is very difficult if not impossible to overrun the PC's keyboard buffer (overrunning the keyboard buffer is a common problem with MAME, the results is lost keystrokes, missed "moves" or the loss of joystick control). Once the PC receives a key MAKE code and acts upon it, the keyboard chip will remove the keystroke from the buffer. How the keyboard buffer overruns in the first place is through the overuse of the typematic function, where too many keystrokes are sent too fast. Since this board has ALL of the PC keyboard command interpreters on board, the encoder can interpret the STOP command, where the PC tells the encoder to WAIT until a free buffer spot is open. The encoder can hold up to 400 keystrokes in its buffer, so with the combination of the large keyboard buffer and command interpreter, this keyboard encoder will not overrun the PC's keyboard buffer and thus drop keystrokes.
I cannot "guarantee" the usefulness of this board for your particular application, but when I used one of these boards to build myself a MAME play-all cabinet nearly 2 years ago, I haven't had a single problem whatsoever with it, and I am playing complex control panel games like Mortal Kombat, Street Fighter II, Time Killers, Gauntlet and a variety of others, and have plenty of inputs left over for future expansion. When playing games like Track N' Field, the encoder does not miss a single lick of the RUN button no matter how fast it is tapped.
Tiger-Heli
    • Tiger-Heli
« Reply #35 on: August 23, 2004, 11:16:54 am »
Something about the above bothers me.  Typematic is not a problem for MAME, but I am wondering about the code only being sent once.
Could someone test the following:
Start Tiger-Heli in MAME using a standard keyboard and hold down the fire key.  The heli should fire 1-2 shots per second at a constant rate.
Now try it with the two-bit encoder.  Does the heli behave the same way, or does it only fire one shot and no additional ones.
Thanks for helping out.
shadowdrak
  • Last login:November 20, 2005, 04:59:54 pm
  • I'm still a llama!
« Reply #36 on: August 23, 2004, 05:25:22 pm »
USB is a great idea but it doesn't work for all situations.  I personally don't car for the USB hype too much because I have found it too be largely untrue.  I have had many issues with USB devices not interfacing properly with the computer -- and this is in the case where I know the device is set up properly because it was working fine ten minutes previous.  Mice and keyboards have suddenly powered off or not turned on at all, confusing since some other devices worked just fine simultaneously.  I have had printers that refuse to keep a steady connection over USB but work fine on a standard LPT.  And I have had irritating buffer underrun problems with external USB CD-r drives in which a burn was initiated but no data was written (still made the disc a coaster).  Some of these problems where on older computer with windows 98, but I still consistently find problems cropping up.  I am not sure if these are because of badly written software and/or driver or what, but in all cases, the devices were used in accorinance with their spec and per manufacturer set-up instructions.
The other reason I don't like USB too much is that it requires the use of a controller chip unless you want to completely hijack the bus(not too kosher).  This almost completely precludes the average hobbiest from entering the arena.  How many of your friends can make a USB controller chip?  Shouldn't be too hard if you have the right equipment, but I would say that it is much easier to write a driver to decode raw data sent over a serial or parallel port than to try to work out USB protocol issues.
I like and regularly use USB devices, but everything has its place.  Just my opinion though.
Bgnome
  • Who's da gnome?
« Reply #37 on: August 23, 2004, 07:49:55 pm »
ok, i did the following test on my win98se pII laptop.  i believe i was running an older version of mame (v0.66 dos pentium optimized i think).  ran tigerhb1.
started the game using my usb keyboard.  held down L Ctrl for a few seconds and proceded to blow up some stuff.  Then I pressed P to pause, while holding L Ctrl.  i released the fire key when the game paused.
i wired CNx7-5 on the Two Bit encoder to ground.  this input corresponds to L Ctrl.  i dont have buttons yet so i just jumpered it to ground using my screw terminals.  Pressed P on my usb keybaord to unpause the game.  the heli kept shooting at the same rate.  i paused again and unhooked the wire.  it stopped shooting.  i held L Ctrl on my usb keyboard one more time to double check and proceded to fire at the same rate again.
bottom line:  works as normal so far..
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #38 on: August 24, 2004, 02:30:25 am »
USB is a great idea but it doesn't work for all situations.  I personally don't care for the USB hype too much because I have found it too be largely untrue.  I have had many issues with USB devices not interfacing properly with the computer -- and this is in the case where I know the device is set up properly because it was working fine ten minutes previous.  Mice and keyboards have suddenly powered off or not turned on at all, confusing since some other devices worked just fine simultaneously. [snip]
The other reason I don't like USB too much is that it requires the use of a controller chip unless you want to completely hijack the bus(not too kosher). [snip]
I totally agree USB is WAY too over hyped.  However, it does look like it's the VHS over the other betas (and over the cassette tapes) in computer I/O ATM.
Robin
Knowledge is Power
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #39 on: August 24, 2004, 03:31:06 am »
Allthough this is going completely off-topic I just wanted to respond. USB is a completeley essential development in the PC world. I have 7 devices connected to my PC and 2 more which are not permanently connected (which would in fact need to be permanently connected if they used the serial port). Imagine plugging in all those devices with only serial ports. Imagine running a Web cam or hard disk over a serial or parallel port. Also, remember the days when manufacturers were making expansion cards to enable you to hook up for instance a scanner. Now you just plug it in and it works. USB adds the power and ease of use needed for further expanding possibilities.
I can imagine people with older computers having trouble, but if you buy a PC nowadays which has problems with USB devices than you should switch brands. Or if you use a hub, make sure you get a proper one and not one you got for free in a cereal box. Of course if people build crappy devices they work poorly. USB has nothing to do with that. I've also had serial devices blow up my serial port.
There are plenty chipsets or microcontrolers available to easily be able to create USB solutions. You can also download basic drivers for them to which you could modify as well. There are plenty ready made solutions there available too. Indeed it's a tad more difficult, but you don't have to create your own chips for it. A proper hobbiest likes a challenge. People who want to remain in the dark ages can still choose so since you can easily connect serial devices to a USB port (with a converter).
