Author Topic: Tron Spinner Question  (Read 669 times)
Zero_Hour
  • Last login:January 17, 2022, 12:45:37 pm
  • Enjoying the irony of taking games seriously
« on: August 11, 2004, 09:21:25 pm »
Hello, I've been a long time reader of this board, and I am finally starting my project. A big part of this project will involve integrating the controls from a TRON CP.
My question concerns the Tron Spinner. Does anyone know if the stock Optical Encoder Board from a TRON spinner can be wired into an optipac? I ask simply because the TRON optical encoder board has 10 wires coming out of it, which is obviously more than a single player setup on the optipac.
I found the manual for TRON via KOLV, but alas my skills at reading technical schematics are nil.
Is there an easy way to do this, or should I consider replacing the encoder board with one from Happ?
"Paradise, is exactly like where you are right now - only much, MUCH better." -Laurie Anderson
exibar
  • Last login:December 28, 2022, 01:42:35 am
  • I'm the creator of Exibar's Lair!
Re:Tron Spinner Question
« Reply #1 on: August 11, 2004, 11:12:27 pm »
I made a control panel using a Tron spinner in the past.  Do youself a favor and get a happ encoder board (or one from a tempest should work too).  You'll make your life much easier for less than $20 and the Happ encoder works perfectly with the tron spinner.
  Mike B
MinerAl
  • Last login:March 21, 2023, 07:11:28 am
  • duck
« Reply #2 on: August 11, 2004, 11:16:45 pm »
I seem to remember that the stock TRON boards are not compatable, or very difficult to interface.
Oscar's optical board and mouse interface should be plenty to get it working.
Zero_Hour
« Reply #3 on: August 12, 2004, 12:34:01 am »
Thanks for the feedback - order placed!
OSCAR
    • Oscar Controls
« Reply #4 on: August 12, 2004, 07:47:51 am »
There is addtional info here, http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=12805;start=msg100055#msg100055, that you may find interesting.
If you use any optic board other than the original Midway one, you will have to do a little modification to make it fit.  What I did with mine is drill a couple new holes through the metal bracket and used some nylon spacers to place the optic board in the proper location with respect to the encoder wheel.
Zero_Hour
« Reply #5 on: August 12, 2004, 09:36:58 am »
Thanks for the link - interesting stuff for the more electronically motivated - which is not me ::)
I think I'll have much better luck fitting the OSCAR optic board as opposed to rewiring the origiinal. The pics of your mod are most helpful.
NoOne=NBA=
« Reply #6 on: August 12, 2004, 10:54:59 am »
I've hooked Oscar's boards up to just about everything I could think of that has an encoder wheel, and EVERYTHING (arcade trackballs, trackball hacks, homemade spinners, steering wheels, etc...) has worked PERFECTLY.
