Author Topic: Need help with light escaping out the sides of the marquee...  (Read 1062 times)
sofakng
  • Last login:February 18, 2021, 04:19:21 pm
« on: August 11, 2004, 12:27:21 pm »
I'm basically at the "fix all the small stuff" part on my cabinet so I'm wondering how I could fix this particular lighting problem...
At the top of the cabinet I have my marquee.  It's attached using Happ's marquee retainer.  The artwork is sandwiched between two pieces of plexiglass (1/8").  Behind the artwork and plexiglass I have a 26" flourscent light (which barely fits).
Now everything works great except I have light escaping at the sides of the marquee.  I'm guessing that I ordered artwork which wasn't wide enough....
Any suggestions on how to fix this?  I've tried placing black construction paper INSIDE the cabinet (behind the plexiglass, in front of my light) but the light still gets through.  I've also tried putting the construction paper right behind my artwork (but in front of the back piece of plexiglass), but you can then SEE the construction paper and the artwork no longer looks right...
Can anybody help me?
SirPeale
  • Green Mountain Man
Re:Need help with light escaping out the sides of the marquee...
« Reply #1 on: August 11, 2004, 12:31:57 pm »
Duct tape?
I'm serious.
Pieman2004
  • Last login:July 15, 2009, 11:29:57 pm
« Reply #2 on: August 11, 2004, 12:35:44 pm »
Some sort of caulking might work.
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #3 on: August 11, 2004, 05:41:04 pm »
Aluminium foil blocks light just fine...   ;D
« Last Edit: August 11, 2004, 05:41:25 pm by JustMichael »
Sylentwulf
  • Last login:October 05, 2009, 09:13:35 am
    • The Electric Quarter
« Reply #4 on: August 11, 2004, 05:42:05 pm »
If the plexiglass is a PERFECT fit, then you can tape off the areas that aren't big enough and spray paint black the tiny light-leaks.
Or, here's an idea I just thought of, Go to home depot and get the foam wetherstripping, and put it on the back of the back piece of plexiglass. Stick it on so it goes too far out to the sides, so when you install the marquee, it squishes the foam, making a perfect fit
BYOAC users get 5% off with coupon code byoac5
etumor
  • Last login:July 04, 2012, 06:56:30 pm
    • Supercade: Classic Arcade System
« Reply #5 on: August 11, 2004, 05:59:46 pm »
A little electrical tape might work, too.
-Jeff "etumor"
NIVO
  • Last login:August 08, 2022, 12:32:13 pm
« Reply #6 on: August 11, 2004, 06:46:31 pm »
i have to go with pieman on this one, caulking is perfect for getting in a crevice, and cleanup is a snap as well. Comes in all colors, grey or black should fit your problem.
