Author Topic: HELP! LAST ISSUE! Games not going full-screen?  (Read 2021 times)
AGGIEZ
  • Last login:January 30, 2017, 05:59:50 pm
« on: August 07, 2004, 04:00:47 pm »
This is the final issue I have with my cab before it's ready to go! (well, I have to get some tinted glass, but that's it). My 19" monitor is setup horizontally. I just switched PC's and the other PC I was using was stretching the games to fit the whole screen. With this new PC, some of the games fit the whole screen (Metal Slug) and others are really small (Marvel vs. Street Fighter, Pacman, Galage - see pic below)
What do I need to do to my new PC to make these games stretch so that they use the vull space of the monitor?
Running MAMEWAH if that matters
« Last Edit: August 07, 2004, 05:19:44 pm by AGGIEZ »
whammoed
  • Last login:Today at 09:05:02 am
  • Crack don't smoke itself
    • NiceMite
Re:HELP! LAST ISSUE! Games not going full-screen?
« Reply #1 on: August 07, 2004, 05:11:43 pm »
One way is to enable hardware stretching.  Of course your video card has to support this.  Maybe that is your issue here...your other pc's video card supported hardware stretching but your new one does not, or you just don't have it enabled in your mame.ini.
The other option is to use something like advmame to set up a resolution that has a close or exact pixel ratio to the resolution of the game you want to play.
AGGIEZ
« Reply #2 on: August 07, 2004, 05:22:01 pm »
Is hwstretching not the defaulf in the mame.ini ? If I need to set it, first of all what is the mame.ini and how do I get to it to make this change?
If it IS the videocard, what kind of card would you recommend? Can you get a good card that would take care of this problem for fairly cheap?
« Last Edit: August 07, 2004, 06:07:20 pm by AGGIEZ »
whammoed
    • NiceMite
« Reply #3 on: August 07, 2004, 09:36:35 pm »
well, I just created the mame.ini with the command:
mame -createconfig
and it looks like it is the default:
hwstretch               1
So what kind of video card do you have?
If yours does not do hardware stretching, yes you can find a cheap video card that does.  I have used the Matrox G400 in the past and it was very good and cheap too.(it is no longer made)  I believe all of the radeon cards will do it too, and I'm sure a lot more.  If you are interested in the G400 I have one available for $25 plus shipping.  It really sounds like its your card.  Some games will look like they are taking up the whole screen because the pixel to pixel ratio is close to even when comparing the games resolution to your monitors resolution but some games don't match up too good.
AGGIEZ
« Reply #4 on: August 08, 2004, 12:37:35 pm »
mame -createconfig
hwstretch               1
I got a pretty barebones PC. This is what it has in it.
 Video:
- 3D graphic acceleration
- 8MB SVGA Memory Frame Buffer
Expansion Slots:
- Three 32-bit PCI Bus Master Slots
- One 16-bit ISA Slot
whammoed
    • NiceMite
« Reply #5 on: August 08, 2004, 12:56:19 pm »
Questions:
Is the video onboard the motherboard or is it a seperate card?
Do you have a free AGP slot?
AGGIEZ
« Reply #6 on: August 08, 2004, 10:29:24 pm »
Questions:
The only slots I have are two 32-bit PCI bus master sots and one 16-bit ISA slot.
I guess I'll have to go with a PCI Video Card...
theonemickfoley
  • Last login:August 30, 2004, 01:37:39 pm
« Reply #7 on: August 08, 2004, 10:53:59 pm »
try using mame32 and and in the options menu choose stretch using hardware
again.
mame has NOTHING to do with the video card only if your using direct3D then it matters..
besides my PCI card is a one megabyte trident card and i get fullscreen on any horizotonial game..
the only ones i have problems with are those pac crap games..
AGGIEZ
« Reply #8 on: August 08, 2004, 11:04:10 pm »
again.
No thanks. MAME32 is pretty lame for a cab in my opinion. MAMEWAH is alot more friendly on the eye and just makes for a better experience. I think I'll have to go to Frys tomorrow and get a PCI video card.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #9 on: August 08, 2004, 11:08:26 pm »
Is the monitor a PC monitor or arcade?
NO MORE!!
AGGIEZ
« Reply #10 on: August 08, 2004, 11:49:34 pm »
PC
whammoed
    • NiceMite
« Reply #11 on: August 09, 2004, 12:10:40 pm »
I am not suggesting you use mame32 on your cab but just download it as suggested before to use as a diagnostic tool to check your video out.  If your card does not support hardware stretching, this option will be disabled in Mame32.  This way you know for sure if you need to go buy a pci video card that supports hardware stretching.
AGGIEZ
« Reply #12 on: August 09, 2004, 12:22:12 pm »
Ahhhhhhh. Good idea. I'll give that a try...Thanks wahmmo!
whammoed
    • NiceMite
« Reply #13 on: August 09, 2004, 12:29:19 pm »
Just checked an ATI rage 128 and it has hardware stretching.  If you need a card this could be a good option as they are fairly cheap and I have seen them in PCI.
SirPeale
  • Green Mountain Man
« Reply #14 on: August 09, 2004, 12:39:05 pm »
I'm guessing that your video is onboard.  Not *always* a bad thing, what's the chipset  for the video?
And to dispell a myth, sometimes the video card *does* matter.  I've got a couple of PCI cards that give me about 3 FPS.  Don't remember what their chipsets were, but they had like 512k RAM on board.  I had one with 2M that did the same.  Don't remember the chipset on that one either.
AGGIEZ
« Reply #15 on: August 09, 2004, 12:39:10 pm »
The "Stretch Using Hardware" option is greyed out in MAME32. I guess that means I need a PCI card then huh?
Peale - it IS onboard. I've pretty much decided to invest in a video card. This is the final piece of the puzzle that is keeping me from enjoying my cab.
« Last Edit: August 09, 2004, 12:41:38 pm by AGGIEZ »
whammoed
    • NiceMite
« Reply #16 on: August 09, 2004, 12:41:09 pm »
Yes, that is exactly what it means.  Off to the store with you! ;D
SirPeale
« Reply #17 on: August 09, 2004, 12:46:21 pm »
You'll be better off.  You should be able to get one from eBay for like $10 shipped.
RayB
  • There's my post
    • RayB.com
« Reply #18 on: August 09, 2004, 01:59:14 pm »
OR you could spend a bit more money on an arcade monitor and run the games in their native resolutions.
NO MORE!!
AGGIEZ
« Reply #19 on: August 09, 2004, 04:33:51 pm »
Hmmmmmm, $10 for a videocard on E-bay or $300 for an arcade monitor. I think I'll go with E-bay.  ;D
SirPeale
« Reply #20 on: August 09, 2004, 04:48:36 pm »
$300 for an arcade monitor?
Oh, must be a D9200 or whatever.  Me?  I'd go with a CGA monitor.
AGGIEZ
« Reply #21 on: August 09, 2004, 05:44:52 pm »
HELP!
I'm not really sure what PCI video card to go with. I looked on E-bay and they have tons of these things. I don't want to buy one then install it only to see that it isn't compatible or doesn't have hardware stretching. I'm running Windows XP Pro. What PCI video cards will run well with XP??
« Last Edit: August 09, 2004, 05:45:58 pm by AGGIEZ »
Sylentwulf
  • Last login:October 05, 2009, 09:13:35 am
    • The Electric Quarter
« Reply #22 on: August 09, 2004, 06:13:25 pm »
I got a radeon 7200 for VERY cheap (might be $20 or so including shipping), and it's fast enough to run most PC games, MORE than enough for mame.
BYOAC users get 5% off with coupon code byoac5
AGGIEZ
« Reply #23 on: August 09, 2004, 08:19:46 pm »
Do they make that for PCI slots? Looks like it's only an AGP card...
whammoed
    • NiceMite
Pieman2004
  • Last login:July 15, 2009, 11:29:57 pm
« Reply #25 on: August 10, 2004, 09:56:52 am »
I am a new at all of this, so sorry if this is a stupid question. I am having similar problems as well. some games do not go full screen but also they are offset a little from center. I am using a radeon 7000 card and thought that radeon supported stretching. so now I wonder if the problem is with direct3D. I don't know though, as I said I am new to this
« Last Edit: August 10, 2004, 10:08:00 am by Pieman2004 »
Lilwolf
« Reply #26 on: August 10, 2004, 01:51:31 pm »
btw, before you go much farther.
you MIGHT consider using SciDisplayDoctor (free) and dos.  It might give you all the resolutions you are looking for.
The initial problem you are having is you have a game that wants to run 320x200 (for instance) but mame thinks your smallest resolutions is 400x300.  So it goes to 400x300 and centers the game.
BUT.  SDD might give you ALL the resolutions normal for arcade games.  So afterwards you would play all games at full screen at native resolutions... And getting the DOS speed increase is also a plus.
It sounds like you have a slow system (based on the video card and lack of AGP port... Only reason I'm suggesting it.
Also.. if you have win98... you can have a dual boot type system pretty easy.
Tiger-Heli
    • Tiger-Heli
« Reply #27 on: August 10, 2004, 03:53:05 pm »
Ok, first try the fixes I mentioned in this thread:
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=22635;start=msg184126#msg184126
Although your MAME32 results do sound like lack of Hardware Stretching might be the problem.
BTW, you don't need a very good video card to make this work, I had an old 4M Rendition Verite PCI card and it did fine for this. . .
