Main > Main Forum
Really tiny keyboard? Or keyboard alternative?
Martoon:
--- Quote from: SirPoonga on August 10, 2004, 01:46:01 am ---This was on /.
http://alphagrip.com/features.html
Well, not exactly what I'd put on a CP, but definitely one of those bizarre, interesting input devices. And you go and tell me about this after I say that I'm a sucker for gimmicky input devices. Damn you, SirPoonga! >:( I bet you offer a lot of drinks to alcoholics, don't you?
This thing looks like it would take some serious getting used to. It's like someone took a keyboard and crumpled it into a wad. According to their website, "It may require 30-60 hours of use to achieve typing speeds of 30-60 words per minute." That sounds pretty bad, but just think, after 500 hours of use, I'd really impress people with my 500 words per minute. ;)
Tiger-Heli:
--- Quote from: telengard on August 07, 2004, 10:06:27 pm ---
--- Quote from: crashwg on August 07, 2004, 06:57:22 pm ---
--- Quote from: monkeybomb on August 07, 2004, 03:29:01 pm ---I set my Keywiz up to type letters on the player 2 buttons when I hit shazzam (shift). Between that and the whats there without shazzam I can do most letters.
I don't know how many letters you need to type but I found that adding just "o" and "k" made a huge difference in my keyboard needs.
Why is it that nobody knows that "left right" on the joystick is the same thing as OK?
It's not advertised I guess. Most people also don't know that you can script the keypresses so you don't have to do anything, although that may be AdvanceMame only which is what I use.
Yep, and it's not that simple., but let's advertise it some:
The scripting thing is AdvanceMAME only.
Left-then-Right actually UI Left then UI right will work for the first screen that comes up. But you could bypass this altogether by creating a mame.ini (run mame -cc) and selecting:
skip_disclaimer 1
And if you don't want the sizing screen:
skip_gameinfo 1
This won't get you past the "Screen flipping in cocktail mode is not supported, Press OK to continue"
But either the hack on SirPoonga's page or NoNAME mame give you
skip_warnings 1
and
skip_bad_dumps 1
which covers all the nag screens.
whammoed:
--- Quote from: Chris on August 09, 2004, 12:52:01 pm ---The one I have is at http://www.directron.com/psk3100u.html, and it's about the same size as that $800 monster.
Thanks for the tip!
whammoed:
I actually like this better than using a wireless because it fits inside my cab:
Chris:
I was thinking about using mine to build a dedicated You Don't Know Jack panel. :)
--Chris
