Main > Software Forum
Changing MAME screen size
Pages: << < (2/2)
Howard_Casto:
Actually the calculations arne't complex at all.  The way mame does artwork files:
Screen Width=1
Screen Height=1
This is regardless of screen aspect, resolution or orientation.
so .1,.1,.9,.9 is always gonna effect the screen the same way.
Edit:
Correction on the coordinates, I had my head wrapped up in the viewer version of mame when I posted this.
They would be -0.1,-0.1, 1.1,1.1  but the exact same concept and ease of use applies.
Tiger-Heli:
--- Quote from: Howard_Casto on August 04, 2004, 08:17:48 am ---Actually the calculations arne't complex at all.  The way mame does artwork files:
Screen Width=1
Screen Height=1
Edit:
My point was that your coordinates will probably work to take 10% off the entire screen, but you could use different coordinates to take 20% off the TOP of the screen leaving an image 80% of original size at the screen bottom.
I can never come up with the numbers in my head, but I could make an art file and make them work if I needed to.
swerv:
thanks guys for all the help.  the artwork solution helped out alot!
Pages: << < (2/2)
Go to full version
