Main > Software Forum
Mamewah w/ Neogeo and TG16
Minwah:
--- Quote from: PiNPOiNT on August 03, 2004, 02:06:02 pm ---You might also have to use the "Dat file" method, if you turn your list into a dat file
type
mame.exe -listxml | xml2info > mame.dat (same dir as mame)
Go into MameWah:
1) Options -> Emulator Settings -> List Generation Settings -> List Generation Method -> ROM Folder vs DAT File
2) Options -> Game List Options -> Refresh Games List
Shouldn't need to in this case as he's using MAME v0.67.
denmiclaw:
I've tried all the listgen methods.. I even updated to the latest Mame version. Still cannot see the NeoGeo games.
Everything is in a rom folder, everything seems to show but the NeoGeo games..
Am I missing a setting somewhere?
Minwah:
--- Quote from: denmiclaw on August 06, 2004, 08:05:44 pm ---I've tried all the listgen methods.. I even updated to the latest Mame version. Still cannot see the NeoGeo games.
I take it you do have the NeoGeo roms??
Try the 'ROM Folder Only' List Gen. Method...all this does is a 'dir' of you roms folder - if they don't show up here then you must not have the roms...
denmiclaw:
I'll try that. But I do have em, they show up and work fine in Mame32.
**update**
Ok, here's what I did. I removed the cfg files for the emulator, then when I went back into the setup, I'm using the mamewah setup, btw, when I chose the mame.exe, and it tried to do the setup, I got an error that the list could not be generated. So, I generated a list using the rom folder only, then re-chose the mame.exe file, then chose Rom Folder vs List info, and it works now.
I'm gtg, so thanks all!
