Main > Software Forum
runtime error 62
Minwah:
--- Quote from: Minwah on August 03, 2004, 06:27:13 am ---Does the error only occur when trying to generate a list? If so, what List Generation Method are you using?
zyxman:
Sorry that must be the reaction that alcohol done to me on next day.. :P
First I have selected the rom folder only option in mamewah and then i go to the
refresh gamelist. After selecting this mamewah crashes with this error message.
When i make a gamelist with the mamewahstetup utility i can create a gamelist
with rom folder only.
But i cant select the the romvsdatfile because the button is deactivted.
--- Quote from: Minwah on August 04, 2004, 06:31:32 pm ---
zyxman:
i just deleted my files folder again, because i
was not sure if the game list file there was
generated with the mamewah setup util.
When i make the list directly from mamewah,
i can generate one with the rom folder only
option. But when i go to the list generation option
and select the romvsdat file the programm crashs
with a runtime error 13 Type mismatch.
I dont know why i m getting another error message
then before. but this could be because i think i generated
the list with the mamewah setup util...
Taylor:
I get the same Error 13 now too when trying to refresh my DAT vs ROM.
Wierd thing was, it was fine until I upgraded my romset.
Minwah:
I have no idea what the problem is here :-\ - I suggest try my next version when it comes out, as it will have some new List Gen. Methods for MAME v0.84+
