Main > Software Forum
ArcadeVGA woes......
Minwah:
--- Quote from: GameDork on August 02, 2004, 02:14:29 pm ---Well, i tried to get the mamewah Res. tool working and still can't get a thing to show up.
- I show it the M.A.M.E. Exe. path, the Ini path and the ArcadeVGA.txt path and NOTHING!!! It brings up the ArcadeVGA.txt list and that's it.What am I doing wrong? I try to "find a game" and it says it can't be found!!
Can someone help?
I think you just need to hit View > Generate Native Res. List. It used to do this automatically until MAME removed -listinfo...
If that works, you need to use the Resolution Selection menu next...
GameDork:
--- Quote from: Minwah on August 02, 2004, 04:33:19 pm ---
Can someone help?
Did that.....NOTHING HAPPENS!! What am I doing wrong????
Minwah:
--- Quote from: GameDork on August 02, 2004, 09:09:06 pm ---Did that.....NOTHING HAPPENS!! What am I doing wrong????
I have no idea what I called it from memory, but there is an option in the File menu to set whether you use MAME v0.83 or later...make sure you have that set right or it won't work...then try Generating the list again...
GameDork:
--- Quote from: Minwah on August 03, 2004, 06:39:42 am ---
The Legacy thing?
I have .84, still nothing..........Just giving up for now >:( >:( >:(
Minwah:
--- Quote from: GameDork on August 03, 2004, 01:44:34 pm ---The Legacy thing?
Sorry I dunno then :(
Basically I just tried it from fresh (delete AMRT.CFG), and all I had to do was point to my MAME executable, and hit Generate Native Resolution List, and it worked (after a delay creating the list).
