Main > Software Forum
Auto CP Filtering
Pages: << < (2/2)
Howard_Casto:
--- Quote from: Random24 on August 21, 2002, 11:13:07 pm ---
To bad you didn't go with a MK64.  It already has the ability to use some inputs as ID bits which can be read by software.
That's true but I think the mk has ghosting and blocking problems so all in all the ipac is still the preferred choice for most.
Random24:
From Ron's own page:
No interference between inputs. No Ghosting and No blocking.
I definitely have not had ANY problems with my MK64.  My CP has 2 joysticks 1 trackball (serial) and 20 buttons and there is definitely no ghosting and I can mash down on all the buttons and have them all read by the sw.
Lilwolf:
MK's have no troubles at all.
I considered doing that, but since I didn't identify my control panels with key presses, I just make it so you could change control panels (with a key press for next/previous cp).
why?
I had (redoing it now) a 4player control panel and I wanted to switch to a 2 player cabinet when there wasn't 4 players..  So I could play player 1 in the middle.
But I didn't set the filter (good idea though) but instead allowed you to have a config for each game for each control panel.  So setup donkey kong for your 4 player CP... then set it up again for your 4way classic CP so you can play it in both.
Pages: << < (2/2)
Go to full version
