Main > Software Forum
MAME OK Removed
SirPeale:
--- Quote from: Howard_Casto on July 30, 2004, 02:23:49 am ---For those of you not paying attention, you should never, ever, ever have to add extra buttons to your control panel to bypass ok. As sirp said, you can simply turn off the screens in the mame.ini and as sirp said, this is covered in the mame faq. And on top of that this question has been asked countless times on this very message board.
He never said add extra buttons. He said:
--- Quote ---This is a little hacky, but if you're using a programmable keyboard encoder (like the I-PAC), you can set the inputs for two of your buttons to be the "O" and "K" keys, then set those keys as player button defaults in MAME.
Nothing about adding more buttons, just changing the buttons that are already on the CP and changing the Mame defaults.
Witchboard:
What's the INI edit to get rid of messages that state the ROMset has problems? Like cocktail flipping?
SirPoonga:
You can't in mame. You need a hacked mame like no name mame to do that.
Howard_Casto:
--- Quote from: Peale on July 30, 2004, 04:20:20 pm ---
Same difference
tenex2mg:
I was just killing time checking around the boards and came across this post, and just had to repond.
I nearly fell out of my char when the "RTFM" was envoked. I just love that one....anyway sorry for the shameless bump.
-jeff-
