Main > Software Forum
Blitz and Showtime, AHHHHH!
the3eyedblindman:
I am even dpoing a jamma set up in my cab, jamma to jpac to pc, so i could switch between pc and blitz showtime pcbs, and i just found out they sill arentr playable because u need 49 way joysticks, im getting frustrated.
pointdablame:
My question is: if you knew those were your 2 favorite games... why did you not look into this before hand?
PS - you should put the same thread in multiple forums... its annoying.
SirPeale:
Blitz works just fine; the problem is it's too slow to play.
Give it a few years, and computers will be fast enough to play it.
SirPeale:
--- Quote from: pointdablame on July 24, 2004, 05:48:45 pm ---PS - you should put the same thread in multiple forums... its annoying.
Right you are. Moved it and merged the topics.
Scoobie:
I'd like to find a copy of Showtime for the PC. Anyone know where to get it? I'm not sure it was ever made for the PC. My google search only came up with PS, PS2, XBOX, Gameboy, N64 versions...
Blitz PC works great! Now if only I could find a no-cd crack for it!
