Main > Software Forum
Orientation in Double Dragon?
SirPoonga:
well then, like I said check your mame.ini file (are you using mame or mame32?) and see if you have rotate right (ror) or rotate left (rol) turned on.
simplygriff:
I'm using mame v 0.82 with MAMEwah 0.97.
At the risk of sounding like an ass... If I had one of those options on wouldn't that rotate all my games? I know mamewah has an orientation option that will rotate games with 1:1 aspect ratios and I tried that think that might help. I don't think I've ever messed with the ror or rol options but I dunno. Thanks again for your help! ;D
-G
SirPoonga:
You are right, ror would rotate all of them. I've tried it in .84 and I don't get his result. Not sure if it is a .82 problem or not.
simplygriff:
Just to let anyone know who may read this later down the road. I fixed this problem by removing the artwork directory in the mame.ini file. In all actualality the artwork was bugging me anyway because I only have so much monitor real estate and the games were just too small.
-G
SirPeale:
Add it back in and turn off bezels.
