Main > Software Forum
Frustrated! Old versions of Mame, etc.
Dougmeister:
Thanks. Where is that? In the properties of the actual DOS window? Will it apply to future instances, too?
Edit: Found it. Thanks.
Dougmeister:
MameWah is working with v0.82 of the Windows Command Line version, but my old computer is too slow for a few games. I'd like to use v0.36 Final of the pure DOS version (games run faster), but when I try to start up a game, I get a Mame error something like:
"Game not found, trying fuzzy match... running calipso"
(or some other ROM that wasn't even close... I forget what it was)
Is this a MAME setting or a MameWah setting (like "Pass long filenames", etc.)?
Minwah:
--- Quote from: Dougmeister on July 21, 2004, 11:11:11 pm ---MameWah is working with v0.82 of the Windows Command Line version, but my old computer is too slow for a few games. I'd like to use v0.36 Final of the pure DOS version (games run faster), but when I try to start up a game, I get a Mame error something like:
Open up the debug.log file in your MW folder...it will tell you what commandline MW is using, and you should be able to see if anything is obviously wrong...
Dougmeister:
Good tip on the debug.log. Needed to turn off options like include extension, use quotes, and some other stuff. Got it running. Thanks.
