Author Topic: Oscar Degaussing Coil not working at all :(  (Read 909 times)
sfetaz
  • Last login:March 11, 2008, 12:58:28 pm
  • DDR4LIFE
    • Home of DDR Machine Rentals and The Madison Square Garden DDR Championships!
« on: July 18, 2004, 11:00:17 pm »
I have done everything correctly on Oscar's site for making a degaussing coil.  However it does not work.  I believe it is because the magnet wire needs to be stripped so that it can make contact with the AC plug and light socket.  How would I go about stripping this wire?  Thanks!
« Last Edit: July 19, 2004, 12:05:27 am by sfetaz »
sfetaz
  • DDR4LIFE
Re:How do I strip magnet wire for making the degaussing coil?
« Reply #1 on: July 18, 2004, 11:43:24 pm »
I was able to strip the wire using a soldering iron.  The light now lights, but the coil itself never gets warm or hot and does not degaus my TV or computer monitor.  I have even tried a 15 watt bulb.  Any ideas?
Zakk
  • Last login:Yesterday at 10:05:51 pm
Re:Oscar Degaussing Coil not working at all :(
« Reply #2 on: July 19, 2004, 12:11:58 am »
Run a -corded- electric drill near the monitor, I've heard that it will act much like a deguassing coil.  Maybe though you have a problem that can't be fixed with a simple deguass?  Try the drill trick though.
sfetaz
  • DDR4LIFE
« Reply #3 on: July 19, 2004, 12:13:49 am »
There is actually no problem at this time.  But when I transport my DDR Machine, sometimes on site the corner gets purple, so I am building one to use.  I have heard about the drill thing but would like to do it the right way.
Apollo
    • Eight Bells
« Reply #4 on: July 19, 2004, 02:10:33 am »
I am havin some gaussing probs but I never heard of the drill solution I'm gonna try it right now!
SirPeale
  • Green Mountain Man
« Reply #5 on: July 19, 2004, 08:27:38 am »
This will work, as it uses the same principle.  You're just evening out the magnetic flow acrosss the screen.
Lilwolf
« Reply #6 on: July 19, 2004, 10:11:43 am »
Is there a reason you can't just use a real maginet?
I never figured out why an electrical maginet works better?  I thought it was the size and being rounded helped... but then why would an electic drill do it (because it would seem like that would produce something similar to a natural maginet)
SirPeale
« Reply #7 on: July 19, 2004, 12:21:32 pm »
You can.  I've degaussed with a hard drive magnet.
You have to make sure you don't turn it at all when you're making your motions around the screen.
