Author Topic: Some questions regarding wiring  (Read 749 times)
lavalamp
  • Last login:July 17, 2004, 11:10:34 pm
« on: July 17, 2004, 11:16:29 pm »
Hi all. im about to buy a second hand cab to run MAME off of. its basically empty, lacking a pcb and such. im going to be using the original JAMMA controls with it. i was wondering what i need to do to to make the JAMMA controls work with my pc inside. ive read about using a keyboard encoder, more specifically, the LP24, along with a JAMMA fingerboard. but to do that, am i going to need to buy a JAMMA pcb to make it work? the cab is just for running MAME of the pc, so im not interested in using jamma game boards or anything.....thanks for your help.
TalkingOctopus
  • Last login:September 06, 2023, 03:39:02 am
    • My Arcade
Re:Some questions regarding wiring
« Reply #1 on: July 17, 2004, 11:21:04 pm »
Since you are not going to use a jamma pcb, you can just wire the controls to a keyboard encoder like the ipac (http://www.ultimarc.com/ipac1.html).  This will interface the arcade controls with the computer.
lavalamp
« Reply #2 on: July 17, 2004, 11:38:20 pm »
Thanks. I saw the things about the Ipac and figured that was what i needed to do. the controls are 2 players with 4 buttons each. Should i be getting an Ipac2 then?
« Last Edit: July 18, 2004, 03:01:14 am by lavalamp »
Apollo
    • Eight Bells
« Reply #3 on: July 18, 2004, 12:44:33 am »
If its only 2 sticks and a few buttons why not use a Keywhiz?
lavalamp
« Reply #4 on: July 18, 2004, 02:09:57 am »
theres also 4 player start buttons (no idea why theres four, got this second hand), and i may expand to 6 buttons each.
« Last Edit: July 18, 2004, 03:02:34 am by lavalamp »
lavalamp
« Reply #5 on: July 18, 2004, 07:54:56 pm »
Oh and since its Jamma controls, does that mean i should get a J-Pac instead? or is that only if im going to be using a jamma pcb and games?
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #6 on: July 19, 2004, 01:10:56 pm »
Does the cab still have the wiring inside?  If it's got a JAMMA edge connector all wired up, you want a J-Pac.
http://www.ultimarc.com/jpac.html
Just plug it in!
