Main > Main Forum
New ThornCab Plans
Aceldamor:
Nice work!!
The only thing I would change is the size of the control panel. But, you already mentioned that ;D You'll have to see if Saint will host a zip file. ;D, unless you have your own site.
shmokes:
This design really suits itself to Golden Tee as well.
BTW, speaking of Virtua Tennis, any way to get it on a cab short of installing a dreamcast or getting an actual arcade unit? Is there a PC version. If so, what type of control does Virtua Tennis use? The dreamcast used the little analog stick, but I've never seen it in an arcade.
Elastikman:
Yes is possible to connect a dreamcast. It a very simple task i think Take a look here http://www.mameworld.net/pc2jamma/arc_dc1.html
shmokes:
I know that a dreamcast can be hooked up, but I'd rather not have to open my cabinet to turn on my dreamcast, plust it would be a pain to hook the arcade controls to the dreamcast in my particular setup.
I'm wondering if there was ever a PC version released or if there are any rumblings about Mame supporting it anytime soon.
Zeitgeist:
Thorn,
I downloaded your MK cab drawings a while back.
Those MK measurements are what I intend to use to build my cab.
Just wanted to say thanks!
Z :D
