Main > Software Forum
VertiPONG *updated to v0.4*
SirPoonga:
Ahh,sound works now :) ok, I forgot to install the font, that's better.
Just suggestions, as this ia a cool simulator. Some knock pong home units you could adjust the size of the bar :)
Also would it be possible to hide the mouse cursor, that's rather annoying.
EndTwist:
Version 0.3 is out. Download from the link in the first post.
Changes in v0.3:
- No more "basic" and "harder" - instead, "Tennis" and "Squash"
- You can turn on color or B&W
- More authentic coloring
- Sizable paddles
- Opposite vertical montor rotation via MonitorType=rvertical
Minwah:
Cool, I like it :)
One thing I noticed using the mouse, is sometimes the paddle will jump say from the middle of the screen to the side. Doesn't always do it just occasionally...
EndTwist:
Odd, you sure it isn't the way you're moving your mouse? I didn't test it too much, so I will probably need to go back to it and take a look.
Minwah:
--- Quote from: EndTwist on July 18, 2004, 03:26:45 pm ---Odd, you sure it isn't the way you're moving your mouse? I didn't test it too much, so I will probably need to go back to it and take a look.
No, it was a glitch of some kind...say I'd be moving the mouse slowly and all of a sudden the paddle would jump to the edge of the screen.
Are you using the mouse cursor's position to move the paddle?
