Main > Software Forum
insert coin (joust) strange problem
SirPoonga:
Peale is right, it isn't a bug, it's the way the cabinet is wired to the game.
MiKman:
So I guess if I want it to function like a single quarter for williams games I need to change the coin2 button (in the tab menu) to 7 instead of 6. Thanks for the information guys I had no idea I guess I can't remember that far back when I used to play joust on a real cab that it had three coin slots...
SirPeale:
Nope, that won't work either. Those games have only two coin inputs.
I started a thread @ mameworld regarding this, just waiting to see what comes of it.
quarterstringer:
I figured out how to change it to 1 credit.
Start Joust or any other Williams game.
Hold F1 down and hit F2 twice
You'll be in the menu
Go to Pricing Selection - Change to 0
Then change Center Slot to 1
Hit F2 to exit.
While you're in the menu, you can also set your own personal attract mode message.
SirPeale:
That 'kinda' takes care of the credit problem. I mean, yes, now it will give one credit instead of four.
I just wonder if MameDev will make the coin inputs correct.
