Main > Software Forum
Marquees for Mame Frontend?? game images
jaquer:
--- Quote from: Bursar on August 18, 2002, 04:38:23 pm ---
Whilst we're on the subject of marquees, I'm having trouble getting Lazarus to display them. I guess they should be in the area above the screen shot, but it stays blank.
If I click through the various images in Mame32, it displays them OK. Does it have a problem with reading them from a large marquees.zip file?
AFAIK, you need to have individual images on the marquees folder under mame. So no .zip here. I'll let HC corect me, since I don't use marquees.
Also (on a slightly unrelated note), I'm having trouble actually exiting Lazarus ;D
If I choose Exit from the menu, nothing happens. I have to launch a game, and then when I escape out of the game it drops me back to Windows.
I'm running XP Pro with Mame32 .61
Am I being really dense?
The exit form the menu is meant to get you out of the menu, not out of Lazarus. To exit, just press the key you have set up as exit/cancel on the key configuration (ESC by default). What I noticed when I was starting to try Lazxarus out was that it takes a sec or two to exit (cleaning up, maybe?), but it does once you press the exit key. Oh, and I'm using XP Pro too and no, you're not being dense. :)
Good luck.
Howard_Casto:
What he said.... :)
