Author Topic: I-PAC problems  (Read 1284 times)
bentley33
  • Last login:July 20, 2004, 07:45:41 am
  • The Force is strong in this one!
I-PAC problems
« on: July 14, 2004, 04:26:25 pm »
Well yesterday I was having problem when I plugged in the I-PAC, XP was saying that it did not recognize the device. After trying everything the troubleshooting guide suggested I decided to upgrade my XP using the service pack 1.  NOW it doesn't see the device at all. Plug it in and nothing happens. HELP!!!!!!!!!! Any ideas?
sirwoogie
  • Supreme Chancellor
  • Last login:April 12, 2024, 10:16:38 pm
  • It's Hollyfeld in a Winnebago!
Re:I-PAC problems
« Reply #1 on: July 14, 2004, 05:42:21 pm »
Which IPAC? Using PS/2 or USB? Are the jumpers set correctly? Are the cables snug on the board and on the computer?
bentley33
Re:I-PAC problems
« Reply #2 on: July 14, 2004, 05:47:55 pm »
Its the ps/2 I-PAC2, I'm using the ps/2 to usb cable. I recieved one of the new I-PAC2s that doesnt have any jumpers.  It is supposed to auto recognize whether it is hooked up using usb or ps/2.
Sylentwulf
  • Last login:October 05, 2009, 09:13:35 am
    • The Electric Quarter
Re:I-PAC problems
« Reply #3 on: July 14, 2004, 06:32:11 pm »
"plug it in and nothing happens" concerns me.
Are you plugging the PS/2 connector in while the computer is on? This is the way we fry PS/2 jacks.
BYOAC users get 5% off with coupon code byoac5
bentley33
Re:I-PAC problems
« Reply #4 on: July 14, 2004, 07:03:44 pm »
The cable I am using is a ps/2 to USB....ps/2 on the I-pac USB to the computer.
And yes I have plugged the USB end into the computer while it is on. That the way USB devices work most of the time. On the I-PAC there is a little green light that give error messages. When I plug the USB to the computer it flashes twice then stays lit. That exactly what ultimarc says should happen. However, the computer never acknowledges that a new device is hooked up. (I have checked the port with a thumb drive and it works fine.) I just ordered a ps/2 cable to see if that will work because I am out of ideas.
sirwoogie
Re:I-PAC problems
« Reply #5 on: July 14, 2004, 11:15:19 pm »
The only other thing I would suggest is deleting all your USB devices, peripherals, and hubs using the device manager and reboot. Leave all your USB components unplugged. Then, after the system is done discovering all the ports, then try the IPAC again.
Also, are you sure you have used the motherboard manufacturers drivers as well? Some mobo companies use special drivers that connect the north and south. nForce is notorious for this.
whammoed
  • Last login:Today at 09:05:02 am
  • Crack don't smoke itself
    • NiceMite
Re:I-PAC problems
« Reply #6 on: July 15, 2004, 12:11:10 am »
Is there another computer you can try it on to rule out the ipac being bad?
bentley33
Re:I-PAC problems
« Reply #7 on: July 15, 2004, 08:31:06 am »
Before I updated my version of XP using service pack 1, I was getting the "unknown device" error everytime I plugged the I-PAC in the  USB port. I tried plugging the I-PAC in to two other computers, a laptop running XP, and another desktop running XP. They both gave the same error "unknown device". I am really stuck....I'm starting to think that I might have a bad card.
photorock
  • Last login:March 07, 2006, 08:37:03 am
  • Goofy Newfy!
Re:I-PAC problems
« Reply #8 on: July 15, 2004, 07:44:14 pm »
        WinXP should pick it up as a Plug n play device and set it up as a mouse with mouse drivers. I know mine did. If it doesn't work on 2 other comps and the cable is plugged in tight , then it can only be a couple of things that could possibly be wrong.
     1. The USB cable is bad, I had that problem a while back with my scanner. replace the cable.
     2.  On the PS/2 conector (USB Cable) a pin is bent or broken. replace the cable.
     3. The I-Pac although aparing to work fine, it probably isn't. replace the card.
        There isn't much else it could be.
PhotoRock
sirwoogie
Re:I-PAC problems
« Reply #9 on: July 15, 2004, 07:51:23 pm »
That is not outside the realm of possibility. Contact Andy at Ultimarc and I'm sure he would be able to help you out. Andy is a great guy and really stands behind the support of his products.
ErikRuud
  • Last login:March 05, 2021, 10:20:27 am
Re:I-PAC problems
« Reply #10 on: July 16, 2004, 09:19:21 am »
The IPac/2 should be seen as a keyboard, not a mouse!
The Opti-Pac should be seen as a mouse.
American Laser Games Wrapper
O2em Rom Utility
bentley33
Re:I-PAC problems
« Reply #11 on: July 16, 2004, 10:19:19 am »
AAAAAAAAAAAAAAAAAAAAAAHHHHHHHHHHHHHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
photorock
  • Goofy Newfy!
Re:I-PAC problems
« Reply #12 on: July 16, 2004, 12:00:39 pm »
       Hey ErikRuud, thank's for picking up my mistake and fixing it. I mean't to say keyboard not mouse. It was late and I was tired...
