May 07, 2024, 01:51:33 pm
they flash when you add credits--what nerd could resist flashing led's on their machine?
dont have an answer to #1, but for #2 the that all can depend on the keyboard you have, plus the motherboard. check your bios to see if you have num lock - enabled or f lock enabled on startup, if so, these led's will be on as soon as the os starts.
Anyone know what the average voltage on a keyboard PCB for the LEDs is? I would guess 5v, and I'm sure I'm wrong.
Quote from: Peale on July 21, 2004, 12:55:47 pmAnyone know what the average voltage on a keyboard PCB for the LEDs is? I would guess 5v, and I'm sure I'm wrong.It is 5v. I tested it a while back because I was bored and had a multimeter.
Then the existing LEDs on the PCB must have a resistor inline. Hmmmm....
Same topic, different question for you folks:If I have a 2-player cabinet, with one lit button for player 1, and one lit button for player 2, is there any use in installing the 3rd LED somewhere??
