Author Topic: I-PAC2 not reconized  (Read 626 times)
bentley33
  • Last login:July 20, 2004, 07:45:41 am
  • The Force is strong in this one!
« on: July 13, 2004, 12:00:40 pm »
I just recieved the I-PAC2 from ultimarc.  When I plug it in Windows XP says that the device is not reconized. I read through and tried everthing that the web site suggested. Any Ideas??????
whammoed
  • Last login:Today at 09:05:02 am
  • Crack don't smoke itself
    • NiceMite
Re:I-PAC2 not reconized
« Reply #1 on: July 13, 2004, 12:15:44 pm »
I assume it is usb?  If so have you tried going into device manager and removing it from the usb section and then replugging it in?  I had to do this on a windows 2000 machine once...geez i hate windows
bentley33
« Reply #2 on: July 13, 2004, 12:25:22 pm »
yep its usb........I've tried that ALOT.......still nothing. Any other suggestion??
whammoed
    • NiceMite
« Reply #3 on: July 13, 2004, 01:47:21 pm »
Is there a jumper on yours that says ps2 and usb?  I ordered my ipac4 with usb cable and the jumper was set to ps2 unlike the first time i ordered.  Just switched the jumper, plugged it in and it worked.  If thats not it maybe you need to email andy?  I don't believe the new ipac2 has that jumper but i thought i would ask. ???
bentley33
« Reply #4 on: July 13, 2004, 01:53:55 pm »
I got a note inside the box that said that I didn't need to set any jumpers.....However there is still a jumper pin set on the board without any jumpers on it.  I emailed him today. Thanks for your help.
whammoed
    • NiceMite
« Reply #5 on: July 13, 2004, 02:31:08 pm »
Actually i think that is the header for the led's.  could be wrong.
bentley33
« Reply #6 on: July 13, 2004, 03:15:59 pm »
You know what I think you are right that is the led header.
DUH
