Main > Software Forum
ArcadeVGA M.A.M.E. Resolution Tool v1.02 Released!
Pages: << < (3/3)
kujina:
I just moved mame to the root of D: and it worked.
Minwah:
--- Quote from: kujina on July 13, 2004, 09:17:09 am ---I just moved mame to the root of D: and it worked.
OK, thanks, I'll try and fix that if I can replicate the problem...
kujina:
--- Quote from: Minwah on July 13, 2004, 06:56:39 am ---
--- Quote from: GMZombie on July 12, 2004, 08:18:16 pm ---hey minwah is there a setup file or whatnot that will allow more resolutions from the arcadevga...only reason i ask this is cause i have a d9200 as well along with the arcadevga and i can get in alot more resolutions in advmame but dont like to put all that time into configuring the advmame. thanx
You can modify the ArcadeVGA.txt file if you like - just add on any extra supported resolutions...
I thought all the possible arcadevga resolutions were already included in the ArcadeVGA.txt file, or are there more?
Minwah:
--- Quote from: kujina on July 14, 2004, 07:09:43 pm ---I thought all the possible arcadevga resolutions were already included in the ArcadeVGA.txt file, or are there more?
Yes you're right...I can't remember if 800x600 is in the standard ArcadeVGA.txt or not, but I think that is the only extra res. that the D9200 will do.
Pages: << < (3/3)
Go to full version
