Main > Software Forum
Help! w/ gamelauncher
Pages: << < (4/4)
Keith O:
You might end up the the same troubles because it's PCI. Does your board have an ISA slot? Hopefully it'll work out but if it doesn't go with sound blaster 16 ISA. It works beautifully in DOS.
mamefan123:
Hey guess what guys, I got the onboard pcu ac97 sound to work in dos and mame I just had to load old drivers and tweak my autoexec.bat and config.sys files. I just received my ensoniq sound card too. Oh well it will work on a another box.
Heres the autoexec.bat
@ECHO OFF
REM  The following command is to support FM Music in Legacy DOS Game
LH C:\VIAUDIO\VIAFMTSR.COM
SET BLASTER=A220 I5 D1 P330
LH SMARTDRV.EXE
and the config.sys
SWITCHES= /E /F
DEVICE=C:\WINDOWS\HIMEM.SYS /NUMHANDLES=128 /TESTMEM:OFF /Q
DEVICE=C:\WINDOWS\EMM386.EXE NOEMS NOVCPI RAM M9 D=256 AUTO NOTR
DOS=HIGH,UMB,AUTO
FILES=80
BUFFERS=10,0
SET PATH=C:\WINDOWS;C:\WINDOWS\CAMMAND;C:\WINDOWS\SYSTEM;C:\VIAUDIO;
SET TMP=C:\WINDOWS\TEMP
SET TEMP=C:\WINDOWS\TEMP
Thats it, it works great. Now if I could only get my radeon 7000 to stop being detected as a rv100 ???
Pages: << < (4/4)
Go to full version
