Main > Software Forum
FE that supports PHYSICALLY rotating the monitor..
SirPoonga:
JoyMonkey, why not even make it simpler and have a frontend that can rotate :)
JoyMonkey:
--- Quote from: SirPoonga on July 14, 2004, 01:36:22 pm ---JoyMonkey, why not even make it simpler and have a frontend that can rotate :)
I just figured it would be easier to write a tiny little app that checks orientation, rotates the monitor and launches Mame. Then it could be used with allmost any existing frontend.
)p(:
I added on request a while back an option that when the fe becomes active again after returning from a game it checks if it was a vertical or horizontal game and rotates the fe accordingly. This way the fe is always rotated correctly.
peter
