Main > Software Forum
Lazarus-How to put in playlist?? and Where to get MAME Artwork??
Howard_Casto:
Oh a couple more things....
I checked the playlist for the backgrounds and realized that the answer is none of the above....
Win mp format is totally f*cked up and it turns out that the recent versions of winamp don't put the drive letter in the path. Your best solution is to put in the drive letter manually from a winamp created playlist.
As for artwork... crash test does a great job of adding keeping snapshots for everything.... that's where i get mine because they don't have those annoying white borders... mameworld.net has links to all the other files....
As for non mame emus... I'm constantly compiling artwork (snaps/flyers/cab shots/marquees/ect) and adding them to my personal build. Once I get a complete set for a emu I release them. If you go to the old raging dragon homepage you'll find artwork for most of the non-mame emus.... I will be releasing a daphne and zinc artwork pack soon.
If you have any logos or artwork that would be of any use please contact me about it. We will try to host as much as possible until it hurts the bandwidth or we can find these packs an official home. If you noticed I released my logos the other day.... the preview shots don't do them justice but I still need more.
Demon-Seed:
Hey,
Ok...in regards to mp3. I still am a little confused. In the Laz dir there is only default.m3u..no background.m3u? where is that stored and you mentioned commenting something out where you type a list..where is that? I checked the Laz.ini file and dir.ini file and I do not see anything pertaining to music or sounds? Please explain as I am a little slow in the head..hehe... :P
Howard_Casto:
background.m3u is new to the betas... you can place one in each of your skin folders and have a list of music to play for each skin... you can also have a default .m3u that's used for the screensaver, which will be scrapped soon anyway...
izaram explained all of that to you in his post :)
Demon-Seed:
Hi,
Ok I took 1 song 1 and made a m3u playlist and named it background.m3u..placed it in the theme dir I want to use but it doesnt play :(... I checked the file background.m3u in notebad and it has the following...
#EXTM3U
#EXTINF:218, Creed - Unforgiven
\Lazarus\Mp3\1.mp3
Now I changed the last line to C:\Lazarus\Mp3\1.mp3
Tried it it still does not play..any ideas?
If you take a MP3 song and name it start it will play. (just a note)
Jim
SirPoonga:
The file name is 1.mp3??? that's weird.
