Main > Software Forum
When does mamewah.cfg update?
Pages: << < (2/2)
Minwah:
--- Quote from: chrisindfw on June 27, 2004, 09:32:45 pm ---Thanks! I know alot of the lcd panels out there use batch files to load them.
Other than that... A great product... I wish I could see the code you have for the layout designer. I could use it to help me at my job. lol
Drop me an email if there's something specific you're interested in...I won't give you the whole lot but I don't mind giving you a start ;)
papaschtroumpf:
Minwah,
How about you copy something to the clipboard (or a file) that describe the "state" of the FE? For example a fixed format string like [emulator][Rom name unser the cursor][status] that someone would parse? (Status could be list/launched/...?)
It seems I have seen this type of request more than once and using the clipboard should be easy for you to do rather than messing with files or sockets.
Minwah:
--- Quote from: papaschtroumpf on June 28, 2004, 12:30:18 pm ---Minwah,
Well I've already done something to add the romname / description to the caption of the main form (window) - I could easily add the emulator name etc. to that - would that be any good here?
chrisindfw:
Well.. I wrote a little program that looks at the cfg file and based on what emulator is loaded, loads a batch file that makes the proper screen on my lcd panel.
Then it starts mamewah...
When you change the emulator, it then changes the lcd screen.
So when you go to the nintendo emu, the screen shows..
Nintendo
Player 1
o o -
bioart:
--- Quote from: Minwah on June 27, 2004, 07:31:18 pm ---
--- Quote from: chrisindfw on June 27, 2004, 06:41:57 pm ---Thanks... Il try it...
Minwah... How does Mamewah use the ipac filename? I am wondering if I can stick an bat file in there to run it?
I hope to add some LCD support soon so I will bear it in mind ;)
Oh yes!, Oh yes!, Oh Yes!
Pages: << < (2/2)
Go to full version
