Author Topic: More painting advise needed  (Read 857 times)
cbmeeks
  • Last login:July 01, 2006, 09:29:58 pm
  • Metroid Classic
    • Metroid Classic
« on: June 25, 2004, 03:59:54 pm »
Ok, I want my cab to feel super smooth and slick.
Is this the way to do it:
1) Sand until smooth
2) Prime
3) Paint
4) Sand ultra-fine
5) Paint 2nd coat
Please note I can barely afford the paint and primer so spray guns, laminet, etc wouldn't be possible.
cb
RETRO COMPUTERS!
A NEW place to chat about retro computers!
RETRO
METROID
Metroid Classic
REBIRTH
  • Last login:December 28, 2023, 09:10:29 pm
  • What is that?
    • REBIRTH "Rotating Arcade"
Re:More painting advise needed
« Reply #1 on: June 25, 2004, 04:45:03 pm »
That is the way to do it.  Sometimes you may want to sand again and put 1 more coat of paint on, but you should be OK with your steps.
:) Rotate or die! :)
Rawker
  • Last login:January 06, 2006, 05:31:24 pm
« Reply #2 on: June 25, 2004, 10:41:10 pm »
sand
prime
sand
paint
paint
don't sand paint lol
dirt
  • Last login:July 24, 2023, 11:06:57 pm
« Reply #3 on: June 25, 2004, 11:11:50 pm »
sand
prime
sand
paint
paint
actually you do sand between coats of paint. just make sure to use a high grit sandpaper and do it lightly.
dirt
WANTED: NINTENDO CABINETS WORKING OR NOT
danny_galaga
  • Last login:May 05, 2024, 10:35:21 pm
    • dans cocktail lounge
« Reply #4 on: June 26, 2004, 05:23:17 am »
i dont know about the US, but in Australia you can get an MDF primer. if youre building in MDF i thoroughly recommend it. its extra thick so it fills in faster. use the finest foam roller you can find for both primer and paint too. This is how mine turned out. The stool was done in the same way
« Last Edit: June 26, 2004, 05:25:56 am by danny_galaga »
Rawker
« Reply #5 on: June 26, 2004, 04:49:14 pm »
actually you don't because it weakens the paint by creating a layer between the two coats which will cause it to be less durable and more susceptible to chipping.
sand
prime
sand
paint
paint
dirt
stevejt
  • Last login:January 01, 2022, 01:21:32 pm
  • stevejt.com
    • My site
« Reply #6 on: June 26, 2004, 10:03:21 pm »
Some people sand between coats, some don't.  I don't.  If it's prepped correctly there is no need.  The important thing-  Make sure the spray paint has a fan nozzle, not one of those round spray patterns.  I have gotten mirror finishes with black, and dark blue with duplicolor brand "body panel" (has fan spray pattern) paint.  Auto part stores sell it, but so does wall mart (cheapest), and k mart.  Also, it might help if you release the button between sprays.  That will stop any running at the end of each spray, like alot of people get.
Steve
