Author Topic: 1/16" vs. 5/64 slot cutter  (Read 3075 times)
somunny
  • Last login:September 05, 2018, 02:22:25 pm
  • Is it hot in here?
« on: June 24, 2004, 05:15:11 pm »
Hi all,
I ordered 3/4" t-molding and a 5/64 slot cutter bit for my cabinet from t-mold.com.  I recently visited t-molding.com and they recommend a 1/16 bit for 3/4" t mold and smaller.
Is 1/64 really going to make a difference?
Coop
IG-88
  • Last login:May 09, 2023, 08:29:46 am
Re:1/16" vs. 5/64 slot cutter
« Reply #1 on: June 24, 2004, 05:36:21 pm »
No. Use what you have. Hot glue makes a good adhesive and will fill in that small of a gap in my opinion. It's also inexpensive.  By the way how much did you spend on that t-molding if I may ask?
-HarumaN
somunny
« Reply #2 on: June 24, 2004, 05:47:58 pm »
Excellent.  I was hoping that I didn't blow 25 bucks on an oversized bit (even though my head was telling me 1/64th was pretty insignificant, you can never be too sure).
As for the molding itself - 3/4" red was 50 cents per foot.
Thanks for the info.
Coop
FractalWalk
  • Newbie
  • Last login:September 20, 2010, 06:12:37 pm
  • Life is time spent fighting entropy.
« Reply #3 on: June 24, 2004, 08:09:48 pm »
I used 5/64 and it was a perfect fit.
saint ganked my avatar.
Blakey
  • Last login:June 16, 2009, 09:28:31 am
« Reply #4 on: June 24, 2004, 08:58:12 pm »
FWIW, I bought 3/4" chrome moulding from t-molding.com, and used a locally bought 1.6mm cutter (1/16").
I didn't use any glue to hold it in, but had to hammer it in place. It's held in very firmly and takes a lot of effort to pull it out, and when it does come out it takes a little MDF with it.
5/64" would be a tiny bit easier to install, and also to remove I would guess.
somunny
« Reply #5 on: June 24, 2004, 11:19:53 pm »
Thanks for the feedback, guys!
I'm really impressed with the way you treat noobs with inane questions. ;D
Coop
JAMMA Guy
  • Last login:June 18, 2004, 01:14:07 am
  • PCB's Are Better!
« Reply #6 on: June 25, 2004, 06:44:13 am »
Same here .. I use plywood and have to use a rubber mallet to install it and when removing it always takes some material with it (no glue required that's for sure ... hehe).
FractalWalk
  • Newbie
« Reply #7 on: June 25, 2004, 10:37:06 am »
I could have installed mine by hand but a rubber mallet was much easier (and better looking). It holds firmly in place but not so firm that it takes out MDF when removing.  IMO, 5/64" is the "right" size.
fredster
  • It's all good!
« Reply #8 on: June 25, 2004, 11:28:42 am »
I have some trouble from time to time doing the t-molding slot.  I guess I don't hold it straight and get tooooo excited cutting the groove.  But I'd recommend the smaller one.
I don't use glue.  I used a hammer.  But the groove got to big and it comes loose sometimes.
